How to disable power antenna
no its easy guys... just take out factory radio --- clip off the pink/blue and black/pink wires and your done! those are the motor activation wires, no motor activation, no whirring!!!
T
T
hey everyone, just in case you are wondering...I finally unpluged my antenna. I concluded that you can't just unplug the relay to the antenna. You DON'T have to remove the flares to get to the antenna plug. If you have running boards, remove the endcap to the board, its 2 screws underneath and one bolt in the wheel well, slide off. Then remove 2-3 bolts that hold the plastic well closest to the antenna. The trick is to go under the trunk, and pull the black plastic well back alittle from the engine side, not the flare side. The plug will be right there. =)
Kinda of hard to explain, let me know if you need more!
#27
well what i did on my 2nd gen and just recently on my 3rd gen is just do an inline switch at the antenna motor.. as mentioned just remove a few clips of the liner and pull it back, it actually will bend out of the way very easily. next locate the wires going to the antenna and folow it back to a connector plug that is higher up on the fender. unclip this to make the splice easier. determine the power wire and splice in your wires and run to a switch. I chose a deck plate switch that i got from a junk yard for 50 cents and as well ran a wire from interior lights to supply light to the nice orange circle on the switch.
#29
Well there are many varietys of the push in clips, and really any will do as long as they are the same size. which type? the ones with the square back that you have to press to corners? the ones that have an internal part that kind of work like wall anchors? you can get these clips from pretty much any body shop, or auto store for next to nothing
#30
umm yea i cant believe this is a problem.... there is a wire on the back of the stock radio i believe it is blue.. anyhow cut that and and no more up/down antenna ( i would suggest cutting while it is up..) i tried to find a wire diagram online but i couldn't locate one..
#31
Just to the left of the ashtray, there is a tan/brown colored box with one phillips screw retaining it. back the screw out, unplug the harness that plugs into it, and lo and behold, no more antennae motor buzzing.
Radio, tape player work fine. Since the O.E.M. cd player has already bit it, it doesn't play.
Reassemble parts previously removed.
#33
unplug relay
here's the deal. just unplug the power antenna relay. it affects nothing else. it is the brown box mounted below the stereo. takes maybe two minutes to get to through the center dash face plate. if you have real small hands and are real limber you can reach behind from under drivers sideand unplug the connector. i unplugged it and the antenna stays down and still picks up stations very well. if you wanted to wire in a switch for the antenna to go up or down it would be much easier doing it from that connector. i think it is the yellow wire that triggers the motor but not sure. probably have to look at a wiring diagram. anyway just wanted to point an easier and cleaner way than tearing out your fender well.[[/ATTACH][/ATTACH][/ATTACH]
#34
#35
Thanks for the info Roadking, made it easy to put my switch in. One thing though, it isn't the yellow wire, it is the blue wire that needs to be cut and hooked up to the switch. Thanks again.
#36
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
theking11863
03-19-2016 09:36 PM
