how to chang to synthetic oil?
ok i want to start using synthetic oil what do i need to do? just chang the oil and filter? or do i need to flush the engine or what? what kind of filter should i use?
Amsoil says to flush your engine before changing over - I drained old dino out put in new synthetic and switched out the synthetic after 3K. Been running Amsoil since (about 40K) with no problems.
From: Far western Kentucky (transplanted from central PA)
You may want to do a search on this topic. There are those that believe that switching over a high mileage vehicle from dino to synthetic is not a good idea.
1. Remove drain plug, drain old oil.
2. Replace plug
3. Remove old oil filter
4. Clean gasket surface
5. Smear a film of oil on the new oil filter gasket
6. Install oil filter hand tight.
7. Fill crankcase with correct volume of synthetic oil
8. Drive 5,000 miles
9. Repeat.
I've changed over at high mileages (98,000 miles) and lower mileages (60,000 miles). My wife can tell a difference in which oil is in the vehicle, though she never knows what I've done. She likes the way the engine feels with synthetic and the '95 4Runner gets about 1 mpg better on it. Can't wait to get it in '99 crankcase as well as the diff, tranny and transfer case.
2. Replace plug
9. Repeat.
are you glad you did?
I have my mom running it in her 97 Infiniti QX4 also. It too runs MUCH quieter.
If you have questions, check out Gadgets page on oil; he has some great insight.
jasonty
41
12-23-2018 02:00 PM
