How can you save a transmission?
My roommate has a '99 Taco 4cylinder auto with 130K miles on it. He bought the truck with 1K miles on it and has never changed the tranny fluid. He knows he's an idiot. Anyways, he says that the fluid is brown but not burnt or black. Is it possible for him to get a tranny flush and filter replaced or screen cleaned and have his tranny not go out? Could he do it twice in a short period of time to get all the trash out of it? Or how about just doing a fluid change regularly until it lightens up?
Will he just be better off leaving it alone? I think there might be a chance he can do his fluid since it isn't black but I'm not too sure.
What do you guys think?
he may be OK doing a change, but there is a possibility that varnish has accumulated around case seals and piston seals, which if its cleaned off may result in external leaks and internal leaks which will affect how the trans operates, its kind of a hit or miss deal
i've heard that a professional power flush would do the trick for him. if the trans isn't acting up then there may not be enough damage yet to affect the performance, albeit, the life of the trans may have been shortened. i'd change the fluid yesterday though.
Originally Posted by Transdude
I certainly wouldn't recommend a flush at this point.
A 'drain and fill' with the next few oil changes would probably be much better.
-John
-John
I'm still open to anyone else's opinions.
Yeah, I've heard rumors that if its never been done, leave well enough alone. I had a Mercury Topaz (I know, a crap car to begin with) that was having slight slippage in the tranny. Like a doofus, I changed it out, and it immediately got a whole lot worse.
Transdude...Why not flush? I dont understand. Is the process fairly agressive with the components or something?
I do, however, remember that when I had the trans flushed in my 87 pathy at 248k miles, it got BAD, and overheated ALL of the time.
I think the lore is that theflush gets rid of some of the "goo" that is actually helping hold things together. Especially if you're already experiencing problems, the damage is done, and goinga flush probably isn't going to magically make the previous damage go away.
-John
crammit442
7
11-29-2017 01:30 PM
chuckross1957
09-07-2015 10:34 AM
kelly1450
09-02-2015 01:29 PM
shrek99352
08-31-2015 05:16 AM
