Last edit by: IB Advertising
- Toyota Tacoma How to Replace Fuel Pump<br>Step by step instructions for do-it-yourself repairs.
How to access fuel sending unit in 99???
Next time you drop the tank, take out the sending unit, reconnect the wires and turn on the key. See if it will go to the empty mark, if it does then all you may need to do is bend the float arm.
After pulling the sending unit out one more time, I found that the internal ground wire was not grounding properly. Instead of tracing the wire, I added an external ground wire and the gauge now seems to work. Time will tell.
Glad to hear that you managed to sort it out (??possibly??), although I am curious as to whether or not you could access the wiring in question through the little access door under the rear passenger seat, or if you had to actually go into the tank to get to the wires?
#25
#26
#27
O'kay.
I'm able to access the wiring harness through the little panel on mine and thought that you could do the same just to test out the circuit, although I guess your problem runs somewhat deeper than that, huh:?
Good luck.
Good luck.
skoti89
09-11-2015 07:46 AM
Odin
07-15-2015 09:28 PM
