Old 02-09-2016, 10:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Hood release cable - adjustable?
Old 09-11-2008 | 02:38 PM
kepico's Avatar
98' 4runner - my hood will not shut correctly - it does not lock down (as matter of fact I failed NJ inspection because of it) I have to stick a screwdriver in there an pop the latch over.
I removed the hood latch assembly and degreased it but still have the problem.
I think my hood release cable may be the problem, when I pull the latch release under the dash it sticks "out" (I dont think that is right I am pretty sure it is supposed to snap closed) I guess there may be too much slack in the cable.
I see no way to adjust the slack out of the cable though?
Old 09-11-2008 | 04:15 PM
DeathCougar's Avatar
No adjustment. I would say the cable has rusted (being in NJ) and will either need lubed, or replaced.
Old 09-11-2008 | 04:18 PM
97ltd4x4's Avatar
Yep,you need a cable.
Old 09-11-2008 | 04:39 PM
btw i would check the latch to make sure its not rusted as well. If the latch doesn't spring back, it wont pull the cable back.
If fact, on second reading of your problem, i would suspect the latch being rusted is actually the culprit.
Old 09-11-2008 | 05:21 PM
kepico's Avatar
Yeah, I did'nt think of it that way, thanks all!
Old 09-12-2008 | 06:37 PM
Angstrom's Avatar
My 98 4runner has the same problem and has been like that for a couple of years. I have used tons of lube and penetrating oil on it and had some one help me keep resetting it as I worked it in, only to have it sieze up again in a couple of days. I just keep a large screwdriver beside the drivers seat now and have taught everyone in the family where to push the latch if they ever have to open it.
Old 09-15-2008 | 05:33 AM
Bandit Runner's Avatar
I have the same issue with my '02. Lubing doesn't seem to help, and I have to stick a screw driver in there to snap the latch back. It would be nice if there was an easy fix for this.
Liadrin
04-25-2022 03:54 PM
jasonty
41
12-23-2018 02:00 PM
okamikai
04-30-2018 11:19 PM
Shaun Crystal Gomban
07-30-2015 11:13 PM
greenbuggy
3.4 Swaps
07-23-2015 12:51 PM
Quick Reply: Hood release cable - adjustable?
