Hole in Transfer Case!!!!!
Dextron II is still sold. Some transmissions are not as forgiving as others. If your tranny absolutely requires Dex II, you can use royal purple as a sub.
UV Dye
Any UV light will do but the cordless ones with a small directional beam work best in tight spaces. You need spceial goggles also. Looks like the dye is about $8 for a 4 oz bottle.
Here's another kit for $60.
#25
Alright guys, I've got some info for you that came straight from my service guy.
Apparently there is a plug or something that is supposed to go there. After a while it deteriorates and you are left with a little fluid leak. He said to go ahead and plug it up with some silicon and everything will be just fine. So it's not a big problem.
I guess we have some pluggin' to do. And I need to check my fluid level in my t-case. I'm just going to use Dextron III.
#28
Originally posted by mt_goat
Wow, thank you. I didn't expect that. Did you look into ordering the factory plug? Was this a Toyota dealership that you went to?
#29
This sounds a little fishy to me. Why would toyota drill a hole there only to plug it? Why does Trunner have a MUCH worse leak than mtgoat? Why is there no factory plug to order? I'll go out and take a look at mine a little later and see there is a plug there.
#30
#32
I agree with you guys. I've thought this was fishy ever since I couldn't find a part to go into the hole. All I can tell you is what my service guy told me. He didn't explain why there is a hole there. He did say that it was fine to plug it, that's really all I'm worried about.
I left the pic with my service guy so that he could ask his tech. The tech saw exactly what we have seen. I trust my service guy. I've never had any problems with him and he has always given me a straight story. Even if it means he will be out of money. I can't argue with that.
mt_goat, it looks like yours is leaking much worse than mine. I hope it's not because all of my fluid has leaked out. I'll definitely have to check it before the trip home tomorrow.
Maybe you guys can dig something else up about it. I have never seen it mentioned until my original thread here a little while back.
Later
Later
#33
I looked at mine and it is absolutely bone dry. I couldn't see inside the hole far enough to see if there is a plug or not, but there is no external plug.
One thing I did notice is that this hole is well above the transfer case fill hole which means it's not submerged under the fluid. You should ask this question over on pirate or even call up marlin, those guys have taken apart toy transfer cases before.
#34
#35
I am wondering if the reason Ted's was pouring out the hole after he filled it up was maybe he overfilled it with fluid? It is possible to over-fill the transfer case if you aren't on level ground when filling or if you hold the fill tube over the hole and sort of dam up the fill hole without letting the excess fluid drain out before putting the fill plug back in. For that mater maybe I over filled mine a little.
I went ahead and cleaned the area with break cleaner and put on a silicone sealent that is resistent to water and heat. I just did this yesterday and wanted it to sit for 24 hours before trying it out. I will let you guys know tomarrow how it worked.
#37
UPDATE
I am a Happy Camper!!!!! All is now well with my transfer case!
I used a silicon based sealent and plugged the hole. No more leaks and everything is back to normal. My gas milage is back up now that I have Dexron back in the transfer case. I will post the extensive Tech Write Up this weekend if I can find the time.
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
