Hissing Air Sound
how can i tell if its the fan? What fan, and where is it located? are you talking about the fan in front of the radiator? If you are I don't think its that fan because i only hear it when the passenger side door is open.
Not sure if this is related but I have a constant hiss or blowing sound coming from the very rear of my rig but only when I'm moving above about 5-10 mph...I think it may be those vents in the back but I have no idea what to do about it.
Fink
Fink
No exhaust smell, its not the speaker. are there any vacuum lines near the passenger side door jam? Kinda near the hinges. I tried to take a video of the sound, but it didn't turn out well, the sound didn't sound how it normally sounds. Thanks guys for you ideas, i guess i will just have to take it into the stealer, and have them check it out.
If it was a vacuum leak the truck would run like poo. I'd go in another direction...in a related note, I would highly recommend a Haynes manual, they generally have a pretty good troubleshooting section.
Well, I am certain that the noise will change if the lid of the air box is opened.
The reason for this is that the air intake for the engine is in that area in the fender and what he is hearing is air being sucked into the air intake.
Gadget
Gadget
hmmmm. yea vaumcum leak would make it run like very nasty runny poo lol. but. like gadet said. if that is where the intake s at?? i dont got a clue. air intake will make a sound. but its usally more of a sucking sound. like if u take out the fatory air box and replace it with a cone filter. it will make a very loud sucking noise because the truck begins to grab much more air into the intake then normal. but i would guess it could have sucked up somethign possably and caused it to sound diffrent
