help where to find bolt torque
I have the Chilton FSM. I just want to make sure your engine is 3RZ-FE? Under engine and engine overhaul 3-41 states torque specs for all bolts are 29 ft lbs (39 Nm) except the 2 front mounting bolts which are 15 ft lbs (21 Nm).
Could you possibly post pics of those I'm trying to get my truck together to drive to school and I can't find certain ones in the repair book but could you post all the torque specs on here or maybe text the pics
Here.....search it:
http://web.archive.org/web/201011261...fsm/index.html
I will assume you are on the mobile app and have the signature lines turned off. If not, and you are on a PC it's in the sigline as FSMs......
no 96 is totally different. you want the 93 one that floating around.
this one http://web.archive.org/web/201011261....1990.1995.zip
I bought mine brand new in August 1995 as it's generally called a 95.5 Tacoma. However, the paper FSM I have says 1995 on the cover.
Either the 1995 or 1996 FSM will work for the OP, IMHO. Seems this one would work just fine: 1995.5-1997 Toyota Tacoma FSM (2)(3)RZ-FE 5VZ-FE
mengquis
07-13-2015 11:39 AM
Jnkml
07-06-2015 02:20 PM
