help with tacoma radio
Old 11-10-2003 | 07:29 PM
coolerthanice's Avatar
My speakers stopped producing sound yesterday and after a little investigation, it appears a wire harness came out the back of the radio. I know it used to be there because I saw it in there a few weeks ago when I took the center apart. However, my problem is I have no idea where the wire harness went!! It is no where to be seen! Anyone with '03 Tacomas or anyone that knows where the harness comes from that plugs into the left side of the radio if you are looking from at the back of it. It is a white harness, it is no the blue ones. I looked for a while and dont know where it could have gotten pulled or fallen down to! Thanks!
Old 11-10-2003 | 08:15 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
2003= take it to the dealer under warranty. That's what you have it for. Let them do the hunting & fixing for FREE.
Old 11-10-2003 | 09:45 PM
i dont want to drive all the way out there all i need to know is where to look for the wire harness. if anyone can tell me i would greatly appreciate it.
Old 11-11-2003 | 11:22 AM
3.4v6's Avatar
my double cab used to do the same thing ... but it only stopped producing sound when i had more than 5 people in the truck ... didnt make sense. when there was only 5 people it worked fine, and it always does that.
Old 11-11-2003 | 11:24 AM
rimpainter.com's Avatar
That is the strangest thing I have ever heard.
Old 11-11-2003 | 12:24 PM
The thing is though, I am pretty sure I have located the problem. The only thing is, I have no idea where the speaker connector went! It doesnt make any sense at all. The white connector is no where at all when I pull the radio out and look behind! If anyone has or can remove the center area (its really easy) and tell me where their wire harness comes out from, I would greatly appreciate it! Thanks!
Old 11-11-2003 | 12:57 PM
DrumheadAR's Avatar
Don't have an '03 Tacoma, but if Toyota still puts the factory amps in them(i'm guessing they do), just locate the amp and the harness should come straight from it. On 3rd gen 4Runners the amp is right behind the radio deck.
Good Luck...hope this helps.
Old 11-11-2003 | 01:24 PM
Tacoma Dude's Avatar
Whoa, that's just bizarre!
You sure you're just not hearing it because you got so many people?
Maybe the added weight? Find some heavier friends and load 4 of them in
Old 11-11-2003 | 02:33 PM
Okay I took a look and realize there is no other wire harness. Toyota does not have a factory amp that is separate from the radio, it is in the radio. My brother had his stock radio replaced on his '02 4runner and taking a look at it, I see the separate amp that has a harness come in and then out to the radio. However, there is no amp anymore...the harness just goes right into the radio. Anyways, my radio stops producing sound randomly! I turn it on, it will play maybe for a a few seconds to a minute, then the sound stops coming out but the radio still plays. My amp still detects signal from the speakers and stays on, meaning that there is still signal from the speakers, just no sound signal. When I turn the radio off, the amp stays on meaning ti still detects signal (but no sound)!!
Old 11-11-2003 | 02:45 PM
Before you show evidence of screwing with it, I would take it in under warranty. How far do you live from the stealer?
Old 11-11-2003 | 03:36 PM
okay i found out what is wrong. there is a loose wiring harness somewhere that deals with the speakers. since i already voided the warranty on the sound system, I am going to find and fix the loose wire(s) by myself. thanks anyways.
Old 11-11-2003 | 08:33 PM
3.4v6's Avatar
strange ... yes it is
mct75
08-22-2016 02:24 PM
G-off
12-29-2015 01:44 PM
Ilovemountains
09-15-2015 05:17 AM
langry345
09-14-2015 04:36 PM
ctheiss
09-14-2015 01:18 PM
