HELP!!! Rear drum removal
I`m trying to replace my broken wheel stud but I can`t get the drum off. I backed off the shoe adjusting wheel fully and I can`t get my bolts to grab into drum due to corrosion of threads (threads broke off on bolt). Anyone have another way of getting the drum off???
Originally Posted by Weasy2k
i have hit the drum with a rubber mallet before and that takes it off....make sur eyour ebrake is off as i made that mistake before
2nd Gen's have two threaded holes where you can thread in a bolt and keep working your way back and forth to pull the drum off. That's the only way I've been able to get mine off the last couple times.
I had one that was stubborn. After soaking it with PB Blaster, I tried to break it loose with a rubber mallet, with no luck. After upgrading to a claw hammer, it came off quite easily.
Originally Posted by Jboy
3rd gens to although my threads are history.
This is probably unlikely, but, hopefully your brake shoes haven't welded themselves to the brake drum...
I had this happen on my first gen. It was so fun. I had to take a dremel (my only cutting tool) and sit for about 3 hours and cut it off.
I then proceeded to run towards the largest cliff I could find. Luckily my friend was there and grabbed me before leaping to my death.
Good luck!
Good luck!
Good luck!
Good luck!
You have the patience of a saint!
Well, I would cut about an inch, take a big screw driver and pry it off al ittle bit.. Cut more, pry it, cut more, then SLAM with a hammer. It was horrible. I was so drunk by the time I was done.
Like I said, there was a cliff close by and I woulda jumped.
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
icentropy
07-09-2015 02:12 PM
