Help Please! Spacer install!!
Old 02-28-2004 | 11:00 AM
93toy's Avatar
I'm installing the Revtek kit on my 97 Tacoma. I've got the spring/strut assembly out, springs compressed. But I can't get the nut on the top of the strut loose without the whole shaft spinning. What am I missing? I don't see anywhere I can hold the shaft while turning the nut to loosen it. Can any of you help please?
Old 02-28-2004 | 12:43 PM
92 Toyota's Avatar
If I remember doesn't the shaft right above the nut have a flat spot? I used an adjustable wrench to hold it then loosen the nut.
Old 02-28-2004 | 01:24 PM
cubuff4runner's Avatar
Some of them will also have a hole in the top to put an allen wrench in to hold the shaft.
Old 02-28-2004 | 01:27 PM
Also make sure you have your spring commpressors on tight and the spring slightly compressed. If you don't that bolt will come shooting off.
nvdesertrunner
05-11-2020 09:18 PM
Swim
9
01-04-2016 11:47 AM
09-04-2015 10:27 AM
punks_is_4x4
08-21-2015 02:35 PM
terminator
07-27-2015 08:13 PM
