Help Please with interior lights!
All,
In my 97 4Runner, the interior lights (map, footwell, and dome) have ceased coming on when a door is opened. Checked fuses and tried opening all four doors individually to see if any would turn the lights on, but no good. The lights all work perfectly if I set switch to "On", but when set to "Door" does nothing. The ground to the lights is not getting from the door jamb switch back to the dome light, but I don't know where to look for it?
Is there a relay, or something else anyone here could help me find or troubleshoot? I tried searching, but found little on it.
Thanks a bunch for any help!
CB
CB
Try cleaning the connection on the switch with a screw driver or pocket knife. If that does not work, try looking at a wiring diagram (there are some online in the repair manual section of www.autozone.com) to see what wire is common to all of those lights. Trace that wire and see if there is a bad connection.
Originally Posted by CBDenver
All,
CB
CB
Good luck in your search..
06-01-2021 02:51 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 09:05 AM
mr_manny
07-31-2015 11:39 AM
