Help please 3.4 injector removal
Old 01-14-2009 | 10:09 AM
chad1041's Avatar
Exclamation Help please 3.4 injector removal
first off i love this site i have always read stuff and found it very useful. just recently got a log in. i got a injector i wanna test (6th cylinder) does anyone know how to get to it or have any links? i will prolly have to replace it.im good with a wrench so any know-how and advice would be very helpful.
Old 01-14-2009 | 10:35 AM
Godzilla's Avatar
Try getting good at the search function. A search even just with the word injector brought these two of many;
https://www.yotatech.com/forums/f2/f...es-how-109389/
https://www.yotatech.com/forums/f2/r...r-3-4l-161711/
Old 01-14-2009 | 10:47 AM
mt_goat's Avatar
This should get you started: http://www.ncttora.com/fsm/2000/Repa...recautions.pdf
Removal of the intake manifold is covered nicely in the TRD supercharger install instructions (note the first page is a blank screen so scroll down a page): http://customtacos.com/tech/files/v6_supercharger.pdf
Old 01-14-2009 | 10:50 AM
mt_goat's Avatar
You beat me hehe, that's a good link
Old 01-14-2009 | 10:54 AM
Godzilla's Avatar
Yeah there are some really good links on here for the fuel injectors. Last winter some of my injector grommets got leaky.
Old 01-14-2009 | 11:09 AM
chad1041's Avatar
thank yall very much be back in a bit to tell how things went
97ltd4x4's Avatar
No links,but..
You will need along with injector,4 "banjo gaskets/washers for the fuel rail"
You can reuse these,but might as well get new along with injector(I know what book says,but I have done this several times,reuse them)
I would reuse the throttle body,and both manifold gaskets,since they are steel..but If you want to replace them,now is the time.
Have rags,gloves and eye protection on hand.
step by step..#6 is drivers rear side..so intake needs to be removed..Start with vehical cold:
1.disconnect neg battery terminal
2.remove gas cap
3. remove intake tube
4.clamp 2 throttle body small coolant lines(or just remove them,they will leak a small amout of coolant so be prepaired for this)
5.remove throttle body
6 remove upper manifold half bolts,wiring grounds brackets,ect,position cables out of the way,cruise,throttle,ect...remove upper manifold from vehical
7.remove lower manifold half bolts..remove lower manifold from vehical.
8. place rags or something in/ontop of intake runners...we don't want to drop anything down there.
9.remove front and rear banjo bolts that connect the crossover fuel pipe,Fuel pressure will release,and fuel will now leak....Use nitril gloves and eye protection and keep a wrag covering bolt/wrench to keep the fuel spray to minimum...also inner banjo gasket might fall...
10.time to remove rail w/injectors..remove 10mm bolts that secure fuel rail,
11.pull up on rail,black plastic fuel rail spacers will fall,be ready for this..you might get some or all injectors to stay in rail or some/all might stay in intake..no matter
12.remove and replace injector.
13.make sure you use a dab of dielectric grease or o-ring lube on upper and lower o-ring.
14.place all three injectors in fuel rail,make sure they can spin freely and are just snug fitting in the fuel rail.
15.now place the entire rail w/injectors back in intake,go slow,make sure the black spacers line up exactly and the entire rail will be seated in the intake.
16.put 10mm bolts back through rail and spacers,untill it they start to seat..
17.check and make sure the injectors move freely(swivel)
18.try and line-up the banjo bolts with the rail and the two connecting tubes...Don't forget to replace the inside and outside banjo gaskets on banjo bolt.
19 snug down two 10mm rail bolts.
20.snug down front and rear banjo bolts...once it seats..no more than 1/4 turn..you will feel them crush...DO NOT OVERTIGHTEN
21.reconnect the injector electrical connectors
22. remove rags from intake and reassemble.
23.after assemble,install gas cap..connect battery cable,turn key "on" several times...CHECK FOR FUEL LEAKS.
24. top off coolant if needed
25.start vehical..may take a few times to get air out of fuel system
26..Finished!
Note..It would be a good time to clean MAF,throttle body and especially IAC valve since you will have it all apart..If so make sure you also pick up an IAC gasket(rubber moulded looking piece)..maybe pulgs as well..since they are right there.
LOl,everyone beat me..I really like how guys come through to help members here..Makes it a great site!
Old 01-14-2009 | 12:30 PM
Godzilla's Avatar
Yup beat you to it, some of use ol'timers on YT have threads and the best search terms pretty much memorized.haha. Thats why I usually bug people to search since I know the information is sitting here just waiting to be searched for! Your help here is always appeciated, no b.s., just answers.
Old 01-18-2009 | 07:21 PM
chad1041's Avatar
thanks again guys for the help bad injector solved easy job with the link's help
Old 01-18-2009 | 07:57 PM
Godzilla's Avatar
Glad to hear it worked out
Blamalam
03-12-2022 08:34 AM
Doug4320
03-24-2018 11:11 PM
Tacoma1313
08-17-2015 06:44 PM
TJWilly
07-31-2015 03:05 PM
Hiluxtrucha
07-22-2015 11:00 AM
