Help picking lift
Help picking lift
I have an 01 4Runner 4X4 and i'm fixing to purchase a 3 inch suspension from toytec. They have two lifts that appeal to me: the 3" 4Runner 4WD Lift Kit W/ Diff Drop and the OME 3" Lift 4Runner Coil Kit. Which one would be the better choice? If you have pictures of these lifts on a runner please post.
the one that includes a diff drop is just a spacer lift up front if i recall correctly. over time these will deteriorate, causing you to get new coils anyways. stock shocks are usable with extended coils, too. i would go with the 3" coil spring lift all around (359.99 i think) and buy the diff drop to ease the pain of the cvs
depends on how much you will wheel. if this is planned to be a road queen than your shocks won't suffer too bad. if you plan on wheeling a good amount it would be wise to go ahead and upgrade to better, extended shocks. you have tons of options, ome, bilstein, just look around
09-04-2015 10:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 02:56 AM
coffey50
07-28-2015 11:55 AM
Backcountry411
07-24-2015 09:06 AM
