HELP loud winding noise in instrument panel (Dash) HELLA ANNOYING
HELP:Loud winding noise in instrument panel (Dash) HELLA ANNOYING
Has anyone experienced this?
I think it may be related to my speedometer needle because the needle bounces around a little bit when it occurs. It happens at speeds above 10mls/hr. It sounds mechanical, it's a high pitch winding noise, and it usually occurs when it is cold out. I'm thinking something needs to be lubed....any thoughts???
Mine did that a few months ago. I ended up pulling the instrument cluster out and sprating some lube down the cable while CAREFULLY driveing around the block.
Worked like a charm.
Cool thanks for the tip! I'll give it a try....
jasonty
41
12-23-2018 02:00 PM
rushw
07-18-2015 02:46 PM
