Help with LED Tail install........
I just got the LED tails for my '00 from Burtman. Thought it was going to be a quick install, but I'm just not figuring it out. They came with no directions, so I'm thinking its just my lack of mechanical knowledge. I did some searching on the topic here and some people were talking about removing the whole rear quarterpanel to install them. I have to use the harness provided, right? After looking at it I don't know how it could be a simple plug and play install. If I knew they were going to be such a pain I would have saved my $$. Anybody know of a writeup for a '00 LED tail install? Thanks guys
can you take some pics of the harness that was given and the old harness and a pick of the connector on both the old and the new lights and i will try and help you
not sure if this will help much but take a look
http://www.toyota-4runner.org/showth...threadid=36196
If I can't figure it out by taking the panel off then I'll post some pics of the harness. Thanks for the reply fatrick
i don't know if your '00 has the rear power outlet on the pass side, but i broke the plastic surround when i was fishing around back there to put in my '02 tails in a couple years ago. just a heads up, mine rattles like crazy still since 1 or 2 of the tabs are broken behind it. just take it a little slower than i did and you won't have any problems. good luck
Got them in. Taking that back panel off was a pain, but after all is said and done the result was well worth it. I'll post some pics later, thanks for the help guys!!
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
bryan34w
12
09-30-2015 02:50 PM
Scotttekoch
09-28-2015 10:30 PM
