help! fuel leak after reassembling from head gasket job
Well i went to start the truck(93 22re)...and there is gas spraying from where the fuel line/fuel rail connect together. I just got done putting this thing together from a head gasket job. I didnt remove the banjo bolt at all... any ideas?
i never took the line off the fuel rail..i connected it right back to the fuel filter(the opening more towards the rear of the truck) maybe i put the new fuel filter on backwards? I dont think that would be the problem, because the gas is getting to the fuel rail...it is spraying right where the line meets the rail.
And what is the vapor return line? I have one line going into the fuel rail more towards the front of the vehicle, and a vacuum line that is towards the rear. Where should that line be connected to? i may have connected it to the wrong spot..
dumbass me....i did loosen the line, and never tightened it..
have one more fuel related question...where does the fuel return line go to. I think i have it right, I just want to make sure.
All is well for now....it's alive!
TURBOrunnerNM
07-22-2015 12:01 PM
