help! cv stuck in diff!
Old 03-28-2010 | 02:00 PM
boostedka's Avatar
ok guys the cv axle is ready to come out but it is stuck in the diff. I have been trying to pry with a pry bar but it does nothing. is there something else i need to do? every write up says it will just slide out....i have a 96 4runner 4wd
Old 03-28-2010 | 02:11 PM
Kerby J's Avatar
use a bigger pry bar like a 3 foot crow bar bc that is what i had to use to get mine out
Old 03-28-2010 | 02:17 PM
Gerdo's Avatar
Also try rotating the axle a few degrees, try again, repeat until it pops out.
Old 03-28-2010 | 02:54 PM
boostedka's Avatar
bought a new pry bar but it is to thick and wont fit so i can pry. used the old pry bar and tried rotating and prying and it didn't work...is there something holding this thing in t have to remove?
Old 03-28-2010 | 03:52 PM
Ironmike4x4's Avatar
I've came across this a few times at work. The best solution I've found is to use a pickle fork and a 5 lb. mini sledge hammer to jar it out. This only works if you are replacing the whole axle though and not just putting a boot. I would recommend buying your own pickle fork instead of using a "loan-a-tool" from autozone or somewhere because you WILL damage the prongs on the fork.
Old 03-28-2010 | 04:04 PM
boostedka's Avatar
ok i got it off thanks for the help. now the new one wont go in...is there a special way it needs to be to insert into the diff?
Old 03-28-2010 | 04:42 PM
May have to turn it a bit, make sure it's the right one. Measure the old cv shaft and compare it to the new one. Depending on where you got it from (autozone, napa, etc.) they may have given you the wrong one.
Old 03-29-2010 | 04:28 AM
Bird-Doggin's Avatar
I had trouble getting mine to go in when I replaced them. I found that the retaining or snap rings that are located on the end of the shaft were spread out too far. I took them off and put the old snap rings on and the axle popped in with no problem. Good luck.
Old 03-29-2010 | 06:04 AM
hross14's Avatar
You can also put it in as far as it will go--then refit the knuckle/hub and press on it to get it to go in--
You seem to be having alot of problems
Old 03-29-2010 | 07:23 AM
exrunner's Avatar
Also, try to put the snap ring on top of the axle, when its hanging down below the axle it sticks out farther and is harder to get the axle in all the way.
Old 03-29-2010 | 07:36 AM
gpcollen1's Avatar
Yeah, much of this is covered in writeups here and there. Give it a whack...
live4soccer7
05-11-2016 07:52 PM
Badlander
10-10-2015 09:05 PM
Odin
09-26-2015 07:56 PM
toyotasaurus
09-24-2015 04:30 PM
zz_denis
09-06-2015 04:43 PM
