Help...battery problems
Hey..so check this out... im having to get a jump every 2-3 weeks...then the battery will run fine.
Alternator?
Sparks and wires?
Bum battery?
I have no idea whats causing the problem...anyone have any idea?
Colin
Alternator?
Sparks and wires?
Bum battery?
Colin
Check the battery to see if it is at the correct voltage. When was the last time the battery was changed? Also check the posts for corrosion as well loose connections.
Most auto parts stores will load test the battery and charging system for no charge. That would be a good place to start. Or for a quick charging test, see what your battery voltage is before and after starting the truck. Should be 12-12.5 volts before and 13.5-14 once the engine is running. And if the voltage checks out fine, might be a problem with the wiring to the starter (if it is not cranking over when you can't start):
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
no corrosion on the posts, the battery is about 6 months old. Ground connection appears to be solid.
Could driving gravel roads kill a battery?
Yes, vibration can kill the plate-style batteries. That is why I always run an AGM (absorbed glass matt) battery like the Optima or my old Black Panther/Odyssey battery:
http://www.4crawler.com/4x4/BlackPanther.shtml
With no thin lead plates, the AGM batteries are very good for high vibration applications.
Location: Far western Kentucky (transplanted from central PA)
I've seen more than my share of alternators "on the verge" of failure over the past 2-3 months. Do the test like 4crawler described but also kick on as much load as you can (i.e., high beams, a/c, etc.) and see if the voltage still holds at 13.5-14 volts.
theking11863
03-19-2016 09:36 PM
