HELP! 92 3.0V6 Rnr Dies out. No cmptr reading
PLEASE HELP!!!
Can someone please help me. I have a 92 3.0 V6 Rnr auto that I have been trying to fix and I can't run down the problem.
I would run great for a while and then it would just sputter and die off. I replaced the fuel pump and it did not help. I checked the diagnostic code steps and nothing registers. It just keeps blinking.
When the engine was running, if I was lucky enough to be around it, I would hear a click near the ECU and then it would sputter out. I used to be able to start it up a little while later. It would run and then do he same thing.
Again, the diagnostic code check does not register anything.
Someone has had to have the same thing, or similar, happen. Is it my coil, a relay etc.
Originally Posted by ajutan
If i would you, i check power supply including battery, fuses and connectors close to fuel pump area, specially ground wire.
James
