heater core replacement in first gen
if anyone has done this recently and has any wisdom they would like to impart upon a fellow toyotan, then please opine. i have never tried this so if anyone has any links or something they hit their head against the wall for. then i would like to hear about it. thanks in advance
I'ts a lota work. I used Chilton and Haynes manuals as guides. If you have a/c, the evaporator has to come out. Start by removing the glovebox, then remove everything between you and heater core. There are no shortcuts that I could find. Just grit your teeth and take stuff out. Good Luck
I think that a/c part under, and behind the glovebox is the evaporater and the condenser is in front of the radiator.
I don't think it would be possible to get the heater core out of my 85 truck, without removing the evaporater. 134 recharge shouldn't be much. With summer comin, it isn't such a bad idea. Just another bullet to bite.
Anyone have any ideas for doing the same on a 2nd gen, or am I stuck taking the dash apart also? There's something blocking the hot fluid from getting through core. I can hear the trickling as I accelerate, but it's usually not very warm (thankfully Toyota put in the floor heater under the center console).
Maybe if not replacing it, is there a way to force whatever's blocking the fluid out? I've already tried using the hose to force water through, but it didn't work. I'm stuck here.
TURBOrunnerNM
07-22-2015 12:01 PM
tpd143
07-07-2015 10:06 AM
Steezy96yota
07-06-2015 11:00 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 05:07 AM
