Heated Power seats
Heated Power seats
Ok I have a SR5 and I will be swapping in some low mileage Limited seats and want to know what I will need to get the heat and power working. I assume if the relays don't come with what I'm buying I can make a harness rather easy for both the power option and the heat. Did the factory option use seperate toggle switches or ....
Aaron
Aaron
Which limited heated seats are these? Mine aren't heated...
edit: nm, 01/02? I wish they made seat coolers..leather sucks when it's 111 here . I put limited seats in my tacoma, and the power was already run under the carpet, I just had to plug it in.
Heck if I know, they might not even be power, but they are in great condition. It's a craiglist purchase that will likely take some time before I get the seats but I have seen pictures. and they are heated and claim to have power.
Aaron
Aaron
Dude the fancy you control your side I control mine hadn't come out yet. And yea if I feel like being a tool your butt is staying cold until you get me some coffee...........
Aaron
Aaron
lol, no I wish. Found the pic while browsing autotrader.
Exactly!
Exactly!
Bringing this back around to the main point of the thread anyone know how to go about making a wiring harness or am I just going to have to do it myself? I assume the electronics will be mounted on the seats and power is to be supplied to that, this is of course using Toyota's logic and not my own.
Aaron
Aaron
I am following along cause I like the idea myself and have a line on a couple of seats here locally. I don't know the answers to all your questions but I am thinking you will need to get switches for the heat and you may want to put them in a different location, like around the center console.
You should be able to just run a fused power wire in addition for the seat functions. As I understand it the passenger seat is not powered, other than for heat.
Perhaps 01-02 Limited owners would chime in here....
Check out my company's install at private residence Jupiter Island-famous singer-we build waterparks-you can probably figure it out. Private m me if you need more clues.
Lastly why would you want heated seats in FL? Just curious-
Last edited by Ron Helmuth; 08-03-2009 at 08:29 PM. Reason: just cause I could....
Aaron
seller jklima in Denver craigslist?
CSL has viewed these part out rigs and may be able to provide better unbiased details on quality and condition
dang I should have snagged those....
you did guess correctly you Great North folks seem to know one another all across the globe
