Head Bolts
Head Bolts
'95 3VZE 3.0 128k miles.
im doing the head gaskets on my 95 runner and i have a question for you guys. are you all replacing the head bolts when you are reassembling the heads. the bolts from partsdinosaur.com are $66, but im ready to assemble this weekend and it'll take a few days to get them to me. id like to know your guys opinion on the matter. thanks for any help.
mike
mike
I'm redoing my '91 3vze and I replaced my bolts from partsdinosaur. In my research I found that the guys that didn't replace their headbolts stated that they wish they did. The machine shop I took my heads to also recommended it. Something to do with head warpage and the torque rating/pressure on the heads. The old bolts "may" not keep the heads even/level with the block. I'd say go with new head bolts.
-=Morphine=-
-=Morphine=-
The bolts are TTY (torque to yield) bolts which are meant to be torqued once then they most likely wont hold the right amount of torque if you try to use them again. Mine came in a kit but you should check with engnbldr and see how much they are, i got mine the next day.
kgcwb44
01-29-2023 10:02 AM
09-04-2015 09:27 AM
whereAreMyPants
07-22-2015 03:32 AM
