Is the Hayden 1679 tranny cooler too much!?
Old 03-15-2004 | 03:26 PM
NX Tacoma's Avatar
Post Is the Hayden 1679 tranny cooler too much!?
I asked where I can get a Hayden 1678 tran's cooler, but when I saw the 1679 I bought it. Is it too much or just right for my tacoma with 125 shot of nitrous?
Thanks'
NX Tacoma
:pat:
Old 03-15-2004 | 04:16 PM
MTL_4runner's Avatar
Thanks'
NX Tacoma
:pat:
If you are putiing nitrous on they bad boy be sure to do the valve body upgrade or you will smoke that tranny of yours, cooler or not. Also make sure todo ome hefty fuel upgrades (I suggest installing the URD upgrade kit to make sure you don't turn your engine into a cutting torch.
Old 03-15-2004 | 04:23 PM
midiwall's Avatar
_WOW_ that must be fun to drive!
You can't get "too much" of a tranny cooler for the truck. Sucking heat out of the transmission isn't like sucking heat out of an engine. You can get an engine too cold, but short of dunking a tranny in liquid nitrogen, it's not going to be a problem.
For reference, tranny coolers are rated by the load on the transmission, expressed in gross vehicle weight. So, referencing:
http://www.bulkpart.com/cgi-bin/miva...egory_Code=HCS
The 1678 is rated for trucks to 24,000 lbs, while the 1679 is rated to 30,000lbs.
The added load of a 125 shot should of course be factored in as additional stress on the tranny. But since you're not running it all the time, the cooler is only there to cool things down _after_ the WOT run, not really during.
Is this an auto? If so, then one thing you should do (if you haven't already) is to do a valve body upgrade. That's going to be more help in keeping the tranny together.
Old 03-15-2004 | 05:47 PM
Transdude's Avatar
A 1679 should work fine if you have the room to fit it.
I'm also going to agree that you will hurt the transmission if you don't do anything with the valve body.
-John
Old 06-02-2009 | 08:11 AM
okie81's Avatar
-John
Old thread, but I just wanted to confirm that the Hayden 1679 will fit into a
3rd gen. It's a little tight, but nothing complicated.
ladybugRC
458
08-21-2020 11:41 AM
TheBFA
02-15-2020 07:55 AM
live4soccer7
05-11-2016 07:52 PM
Davebarbier
11-03-2015 04:28 PM
scott90
10-04-2015 10:21 AM
