Grind going into 4L and back into 4H w/selector lever
I have a 1997 4runner Limited automatic with the 4WD/4H push button on the selector lever (which works fine, btw).
With the vehicle stopped and the transmission in neutral, I get a grind when moving the selector lever from H to 4L. If I slowly move the lever toward 4L, I can feel that gears are still turning (similar to bumping the shifter into a gear in a manual tranny w/out the clutch depressed...if that makes any sense). Anyway, if I grab the selector lever and purposely pull it into 4L, it moves right in, but with a slight grind. Moving back into 4H is the same.
Otherwise, everything works great when in 4H, 4L, and 4L w/rear diff lock.
This doesn't seem normal, and the one thread I found about grinding into 4L and 4H said it's most def not normal. So, any idea what's up?
Dave
Dave
Since the t-case gears aren't synchronous, moving the lever slowly lets one gear spin up while trying to engage with a stationary gear. A quick, firm throw of the lever will usually prevent any grinding.
![thinking](https://www.yotatech.com/forums/images/smilies/think.gif)
1 Post
My guess would be that with the auto there is enough spinning in the trans that the fluid has enough drag to make things spin. This transfers to the transfer case whan shifted. You go thru neutral on the transfer case to get to 4Lo. The longer you are in N the more it will spin. If you shift swiftly from 4Hi to 4Lo there should be less grind.
Does it grind more when it's cold out? When the trans is cold (haven't driven far)? How old are the trans and transfer fluids? Conventional or synthetic oils?
My trans used to grind and was hard to shift on my old British car (TR6) until I switched to synthetic trans oil.
![Frown](https://www.yotatech.com/forums/images/smilies/frown.gif)
I'll try that tonight.
IMHO the best thing to do is throw the tranny in neutral at around 1 mph, let the vehicle decelerate to where it is about to stop, then give the t-case handle a quick, firm tug. Between the tranny being in neutral and the moving vehicle turning the t-case gears, you are assured that things will mesh without risk of any gears spinning too fast. The worst thing you can do is move the t-case handle slowly allowing the gears to grind before becoming fully meshed.
Cold gear oil will always aggravate gear grinding, even in trannys with synchronizers.
![Thumbs up](https://www.yotatech.com/forums/images/icons/icon14.gif)
Hi,
I've been looking for information on my transfer case grind for weeks.
I have done a complete oil change in the gearbox, drained the transfer case, changed the transfer case but still these grind except when the oil is very hot.
And this subject informs me that I take too long to go from H4 to L4 and vice versa, as a result the secondary shaft starts to turn and this prevents the transfer case from shifting. THANKS!
My truck is a 2014 Toyota hilux, 3.0L diesel 171 HP, from France.
But I wonder if all hilux like mine have the gearbox secondary shaft that starts to turn when the gearbox and transfer case are in neutral
4RunnerCollegeKid
22
11-08-2020 03:32 PM
Dave M
12-23-2007 11:00 PM
