green and red coolant
Old 02-08-2007 | 11:54 AM
mkgarrison5's Avatar
hey guys, not thinking, i bought some of the prestone green GOOD FOR ALL COLORS antifreeze a few weeks ago. i drained my radiator and refilled with the green good for all colors 50\50 antifreeze.... i am guessing i should dump that out and refill with toyota coolant or can i just leave it alone??
Old 02-08-2007 | 12:49 PM
MARSHALLMAY's Avatar
If it came with it, I'd go with the orange "dexcool." It prevents aluminum corrosion and extends water pump life.
Old 02-08-2007 | 12:54 PM
spaugh's Avatar
i did a flush and filled with the green. I'm running cooler than ever and its been 4 thousand miles. It doesn't matter what you use, they are both fine.
thats good for yotas?? just curious. i know around where i live dexcool isnt as available as prestone
Old 02-08-2007 | 12:55 PM
well i didnt really flush haha.. i just drained really well. ran a half gallon of water through it shut the plug and refilled with green
Old 02-08-2007 | 01:00 PM
shiftless89's Avatar
(high acid coolant)
DON'T DO THAT, there is a reason GM techs call it "death cool" ( I deal with dealer techs from several dealerships on a daily basis) This argument has been beaten
the red toyota is low silicant which in turn means low acid which equates to longer life. Remember toyota's go 1/2 a million miles on toyota products not gm, not prestone.
is it worth the 5.00 savings to replace your thermostat housing, water pump.............................
Old 02-08-2007 | 01:01 PM
I'm sure it will be fine with the green coolant. It won't cause any immediate problems and probably won't cause any long term problems. I use orange because that's what Toyota put in it.
Old 02-08-2007 | 01:02 PM
rdharper's Avatar
There are a lot of smart people I respect, on this forum, that will essentially tell you: why take a chance, stick with Toyotas product.
Otoh, there is nobody that knows more about antifreeze, does more research, is a bigger company that does nothing but anti-freeze, than Prestone.
I'd say you are perfectly safe. Prestone specifically claims it is ok for your vehicle. Probably the most important thing is that you changed it. Also, that 50/50 mix makes it idiot proof. Makes it easy to get it right. I say thumbs up.
Old 02-08-2007 | 01:04 PM
MTL_4runner's Avatar
Ok, no, not all coolant is ok to run/mix and Dexcool least of all.....I went through the same thing and while back.
You guys need to read the overload-of-info coolant thread:
https://www.yotatech.com/forums/f2/just-finished-timing-belt-coolant-question-77747/
Old 02-08-2007 | 01:24 PM
well ill leave the geen in for now. i drive ass loads of miles so this time next year or earlier ill flush it out and just use the yota red or pink. thanks for the info..
Old 02-08-2007 | 01:39 PM
itsmeagain5789's Avatar
i've had the green coolant in my 3.0 for about a year, 15,000 miles. its running great.
Old 02-08-2007 | 01:43 PM
PirateFins's Avatar
Dexcool bad (ask my father about the top end rebuild on his Jimmy because it ate it away) and is the only one I know of with a class action lawsuit, prestone ok, Toyota good.
Old 02-08-2007 | 02:16 PM
Beartracker's Avatar
YOU CAN NOT USE THE GREEN IN A TOYOTA ENGINE!!! You guys who are stating that it's alright because you have been using it for a year or so are completely wrong and will pay dearly in the end.
The red or the whatever antifreeze MUST HAVE Ethylene Glycol in it for the Aluminum radiator that is used by Toyota. The green or any antifreeze WITHOUT THIS ADDITIVE will corrode your engine and radiator.
When your not sure about this stuff please read your manual or call the mechanics at Toyota . The manual states that you MUST use Toyota antifreeze or the equivalent and it must have the chemicals stated above our you will cause damage.
No, toyota did not put orange in it, Toyota & Lexus only use RED long life coolant
SEE THE POST ABOVE THIS.
please be careful both taking and giving "E-vice" as "I heard its Ok" can cost you a lot of money and time in the end.
Old 02-08-2007 | 02:45 PM
my bad, looks orange. I assumed it was dexcool. I never really researched toyota coolant. I was careful before giving e-vice because putting the wrong coolant in won't cause a catastrophic problem. And it is only a suggestion. "i heard it's ok" leading to expensive problems would be something like "yeah, I heard it was ok to put motor oil in your transmission."
Old 02-08-2007 | 02:53 PM
rdharper's Avatar
The color red, green, orange etc have become a trap in the sense that their are no observed standards by color. One needs to know what the specs are if you choose to use something other than the recommended coolant.
In the case of Prestone 50/50, they are well aware of the requirements (imho).
But if you want to be absolutely sure, do the simple (expensive thing) and use the dealers product which Toyota sells. And don't forget to always use the dealers parts. They are OEM also. And while you are at it, always have your work done under a Toyota authorized dealer.
Get it?
Old 02-08-2007 | 03:22 PM
jonwanner's Avatar
the prestone coolant is ok to run in your toyota, but it is not a long life coolant, and so it needs to be changed more frequently than if you used the RED toyota coolant. DO NOT USE DEX-COOL. It is crap, and it will eat your cooling system. There are ways of testing the PH level of your coolant. you want a slight base. When the coolant becomes acidic, it is time to change it, becasue that is when electrolosis begins to eat your cooling system.
Old 02-08-2007 | 03:26 PM
Ok, since your a Texan, I'll forgive you. I base my "e-vice" on hard fact. I currently work for a Lexus dealership and was previously at a toyota dealership. and Have a broad profesional history with auto's and the required repair in general. I have seen numerous coolant related failures ranging from failed:
radiators, water pumps, eroded heads/blocks, thermostats/housings. This is in vehicles run with "dexcool" and from the various brands of green coolant available. (in all makes and models of vehicles.)
also the gell effect of mixing red and green coolant, its pretty nasty!
I have seen failures in vehicles with "red" coolant as well but mainly due to the age or wear of the failed part, not due to erosion.
your rig may run fine for the next 15 to 20k miles on green, but you are indeed shortening its service life.
and if you really feel like putting oil in your transmission, let me know when, I'll grab a 12 pack, a camera and head your way
Old 02-08-2007 | 03:42 PM
YodaPala's Avatar
Did any one elese get a class action law suit in the mail against gm (if you own a GM) about the dexcool?......thought I'd bring this up while y'all are talking bout antifreeze. Thanks
Old 02-08-2007 | 03:46 PM
what does the lexus auto transmission fluid smell like to you? It reminds me of strawberries...
