govern mod?
Old 05-11-2003, 11:14 AM
Duffdog's Avatar
hi yall
that was me, and it was 147 ( i had an apex digital speedometer also --the stock speedo isnt much help )
-- to remove the governor on tacomas and 4runners, you need to put a switch on the green/orange wire going into the ecu. you cant just cut it permanently or the check eng. light will come on because the ecu requires a speed sensor input for anything more than 25% throttle. So, put a switch on the inside of the glovebox which allows you to turn off the speed signal going into the ecu when you want to go fast. then switch it back on when your done racing. You would be surprized how much the truck picks up at high speeds with a supercharger.
This is at your own risk of course, i have Z rated tires and 17" rims on my 2wd. I wouldnt want to go that fast with some 35" tires, that could be dangerous.
tim
Old 05-11-2003, 11:36 AM
JGage's Avatar
Prescott
I LOVE PRESCOTT !!! There is a really good place to eat there called "The Rose." Pretty country too.
Old 05-11-2003, 11:46 AM
az4x4runner's Avatar
Do you work at Gunsite?
Old 05-11-2003, 12:48 PM
midiwall's Avatar
Originally posted by Rymin929
Ive seen that too, but the question is still how are they telling there going 157 mine's a Tacoma too but my speedo still only says 110 like the rest of em'.
The "right" way is to rig an external spedometer like DuffDog did. But, you can get a rough estimate from reading off of the tach.
Note the RPM reading at 60mph while in your highest gear. Divide the RPM by the MPH to get a divisor. So, if you were running 2300rpm at 60mph then the divisor is 38.333.
When you're topped out with the spedo, note the tach reading. Take that reading and divide by the number above to get your speed. Say it was 4200rpm, so 4200/38.333 = 109.56.
Obviously, the more accurate you can be with the RPM and MPH readings the better. An OBD II reader can help a lot in doing this.
Old 05-11-2003, 01:15 PM
  #25
JGage's Avatar
No, but I've been there a few times.
Like I said, nice town.
Old 05-11-2003, 06:40 PM
  #26
Bumpin' Yota's Avatar
Originally posted by Duffdog
hi yall
tim
So when you have the governor ecu setting "off" for racing, the "check engine light" is on until you switch it back to "on?" Is it the same for all yotas? I have a '90....
My 2nd gen tops out at 98 on flat ground at 85 degrees and 85% humidity. Going down a hill the governor cut out the engine at ~105 - I scared the absolute dog poo out of myself, cuz I thought I had somehow killed my drive train. That discovery of speed limitation was over 2 yrs ago, I try not to speed at all now....
Steve
Old 05-11-2003, 06:51 PM
  #27
HaveBlue's Avatar
Rymin929-
I PM'd you!
Old 05-13-2003, 01:54 PM
  #28
Duffdog's Avatar
the check engine light comes on only when the computer sees 2 consecutive starts and throttle input of 25% or more. by switching the governor off while the engine is already running and switching it back on before you turn it off, you effectively bypass that algorithm in the ECU and the computer thinks that everything is cool Leaving the governor bypassed while starting the truck is how you get the light to turn on.
tim
Old 03-12-2004, 04:58 PM
  #29
I still haven't even touched the wire yet on the ECU to bypass the governor, but would it be orange/green for a '90 4Runner? Where could I look that up?
Old 03-13-2004, 06:38 PM
  #30
Duffdog's Avatar
maybe thats the wire--im not sure. anyways, to find out, get a factory shop manual and look for the sp1 wire-- youll have to know something about electronics to figure out where to access the wire for the right results. it should be the same deal-- I know that on my old 90 toyota, there was no speed governor--it just didnt go any faster because of the restrictive exhaust. when i changed that the truck went to 130mph (topped out, 4th gear)
T
Old 03-14-2004, 03:22 PM
  #31
Zubaltec's Avatar
URDUSA has the answer. Check out there web site.
John
TheBFA
02-15-2020 06:55 AM
punks_is_4x4
05-31-2016 06:03 AM
voiddweller
53
02-01-2016 05:46 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
Quick Reply: govern mod?
