Got my arms back on! :)
Old 09-26-2009 | 02:27 PM
BajaRunner's Avatar
After about 4 years of the Trailmaster lift and the funky 2nd struts they use to replace the upper A-arms, I ended up getting some Fabtech spindles and put the upper A-arms back! I'm stoked. The drive is already much tighter, and now I don't have to worry about popping the mounts off from the old setup (Done it before).
They are super beefy and weigh in at 55lbs each (the spindles).
Old 09-26-2009 | 02:35 PM
Fink's Avatar
Looks great.
Fink
Old 09-27-2009 | 10:04 AM
eddieleephd's Avatar
time for a good party!! looks great
Old 09-27-2009 | 07:57 PM
desertcamper67's Avatar
Looks like it went well. Did this fix your ball joint/control arm bushing problems?
Old 09-27-2009 | 08:08 PM
jibbles's Avatar
your 4runner is so beastly
Old 09-28-2009 | 01:13 AM
awpsome's Avatar
damm nice how high is that?
Old 09-28-2009 | 07:56 AM
BajaRunner's Avatar
DesertCamper --- I had my mechanic friend down the street go over the bushings and ball joints with me, and we did some movement tests to find out that everything was fine. I mean, yeah I could use some new parts since they are old, but they are not failing. I think the main problem was my old lift setup. It was janky and caused a lot of movement. Hopefully they will just align my truck now.
awpsome - look at my sig-line. I have a huge writeup and information on that link.
Old 09-28-2009 | 11:34 AM
SnowRunner98's Avatar
Swweet, glad you got er' done.
Old 01-16-2010 | 05:12 PM
blackdog42's Avatar
I have been wanting to do this for a couple of years. Glad to see that the mod works. How much did it cost you and where did you get them from? Thanks
Old 01-16-2010 | 08:27 PM
JamesD's Avatar
I noticed you broke a rear axle shaft. By any chance before this broke, did you have the rear axle bearings replaced?
Old 01-16-2010 | 09:57 PM
BajaRunner's Avatar
Blackdog: I bought them used from TTORA. You can buy them for about $300-400 each from 4wheel parts or Offroad warehouse. :/
JamesD: No I hadn't had my bearings replaced. I'm still uncertain to why the shaft broke. I contacted Toyota, and they didn't have any answers or information. It was a scary situation due to the fact I was driving at about 45 mph when it broke and pulled out of the housing.
Old 03-30-2010 | 10:25 AM
Coolidge's Avatar
That is awesome! I saw about your fix on TTORA, and wanted to get some input from you? Im looking into getting these knuckles (before I weld #2 crossmemebr back!) I hate my POS TM lift, was going back to stock, but this may be the way to go?
I bought my truck in San Diego BTW
Has King CO's in front w/Bilstein 5125's rear
Old 04-02-2010 | 03:04 PM
Coolidge's Avatar
OH well...back to stock with King coil overs.
FWIW, you CAN reverse a drop bracket lift w/cut crossmember.
You are very lucky to scoop those knuckles u$ed
Old 04-27-2010 | 10:28 AM
Coolidge's Avatar
Its going quite well....
[IMG]http://img.photobucket.com/albums/v25/Guyster/crash2_10_2010027
.jpg[/IMG]
Kit:
Man, I "hope" its straight! lol
Just back from alignment. Heres a complete pic. Same wheels, no spacers, 285's instead of 35's. Best off, no more DB kit
Hytenor: Align specs before
Align specs after:
Old 05-01-2010 | 09:28 AM
BajaRunner's Avatar
Wow, nice job dude.... !
If I really disliked the DB lift, I'd go that route.
bigjstang
08-25-2021 01:41 AM
razorman8669
07-12-2015 01:13 PM
Kluch8651
07-09-2015 11:39 AM
ptb12
07-05-2015 02:49 PM
elwood73
07-05-2015 08:07 AM
