going to 305s from 285s, fitment?
Old 06-06-2009 | 02:54 PM
kmcaprice14's Avatar
Hey, I searched a bit for this (to no avail), but just wanted to check to see if anyone had done what I plan to do. I currently am running Goodyear Wrangler Silent Armor All Terrains (285/75/16) on 1995 landcruiser rims. I am up 2-3" on 881s and 890s. My current setup works great (no rubs at all once i hammered back the pinch weld). I am looking to go a hair wider for the sand (its a beast already in the sand, but as I frequently help pull people out, a little extra sand "buoyancy" wouldn't be so bad). 305/70/16s seem about perfect. I can currently fit the thickness of my hand between the upper A arm and the sidewall, so I think this will work. I just wanted to see what opinions anyone had, or if anyone had done this. I will be going with BFG ATs next (Although I did love the silent armors). Will I need an inch of Body? I'd prefer an all suspension lift...
Old 06-08-2009 | 09:27 AM
SnowRunner98's Avatar
guess you can get one mounted up and see if you don't rub your a-arm, or get some shaved a-arms!
Old 06-08-2009 | 04:28 PM
yeah, thats true.... I was just hoping someone had a similar setup. 285s just aren't that wide. Thanks for the response
Old 06-08-2009 | 06:03 PM
t0mwat3r's Avatar
There the same size height wise but the 305 is about an inch wider, so you would have to be sure your backspacing will work
285/75/16 = 32.8x11.2/16
305/70/16 = 32.8x12/16
Old 06-08-2009 | 07:11 PM
hell, i think im going to do it. I'm pretty sure I have room with my A arms. My real concern was with the tire hitting the body with the wheel turned under compression. I can't really hammer back anymore. Next time I see a sale, I'll throw some 305s on there.
Old 06-09-2009 | 07:57 PM
oh go to a tire shop, and have a couple mounted..
Old 09-11-2009 | 05:03 PM
LockedLex's Avatar
How did this turn out. I'm looking at 305/70 16 because that's the only 33 available in the tire I want. I will be getting a 2.5" suspension lift (through SS System 1.2).
Old 09-11-2009 | 05:55 PM
4RKidd's Avatar
i run 305's and you need front spacers to clear the a arm, i have 1 in.. you will rub on the fender. pound in the pinch weld and cut the lower corner of the fender. and youll be just fine..
Old 09-11-2009 | 06:00 PM
LockedLex's Avatar
great, thanks for the follow up 4RKidd. Got any photos of your rig? I was concerned w/ the SS 1.2 (2.5" lift) that the 305/70 will not clear w/o serious mods... but it seems like a little trimming, and spacers etc, I can deal with. I want to keep the stock Limited fender flares though... do you think that would post a problem?
I want to get the MT KM2 from BFG, but their sizes are 265, then 305. no 285 offered, ugh. How is the power/mileage, etc. with those 305s?
Thanks again!
Old 09-11-2009 | 06:38 PM
waskillywabbit's Avatar
Sonoran Steel has all the details on his website how and what to do to clear 35s on a 3rd gen.
Old 09-11-2009 | 06:40 PM
LockedLex's Avatar
Thanks wabbit... though the 305/70 seem to only be 33s (I would prefer 285s, though the KM2 don't come in that size).
Old 09-11-2009 | 10:27 PM
brian2sun's Avatar
I'm going back to 285s from 305s (on now). I have to run 1" spacers in the front and not the rear. If I run spacers on the rear, the wheel wells sit on the last 1" of the tires. W/o the spacers I can just barely stuff the rears w/ a little rubbing - not really that bad, but it still gets old. Fronts only rub on the frame a little when fully turned to one side, nowhere else (after some cutting and pounding).
My $.02, the little extra width you gain isn't worth the rubbing. And yes, the KM2's do come in 285s....look....
http://www.bfgoodrichtires.com/specs...-km2/3930.html
Old 09-11-2009 | 10:47 PM
brian2sun's Avatar
BTW, I have a 2.5-3"+ sus. lift.
Old 09-12-2009 | 12:57 AM
LockedLex's Avatar
Thanks Brian! That's what I get for going to my favorite tire website, rather than directly from BFG-must be Friday fog... since that didn't even cross my mind.
Yep, it'll be the 285s then for me. I just don't really need that extra width. Thanks again!
Old 09-12-2009 | 01:32 AM
brian2sun's Avatar
You bet!
kawazx636
10-06-2021 04:03 PM
jaretstuff
10-22-2015 06:25 PM
4runner4me
02-24-2004 10:16 PM
mikes97
11-12-2003 12:55 AM
Mudd Runna
12-05-2002 11:24 AM
