GEN 3 Switched 12v tap?
Old 10-02-2004 | 07:31 AM
Beach-Rat's Avatar
I'm re-doing the first owner installed items on the '96 by adding a "painless wiring" (homemade) switched sub-fuse panel…
Oh great Gurus, where is the best place to pick up a switched 12v control lead?
I have searched under the hood and dash (without disassembly) and nothing “jumps out at me.. Am leaning towards the 15 amp accessory fuse but I can’t locate drop side access outside of the harness..
Ideas? What has worked for you?
Old 10-03-2004 | 05:08 AM
MTL_4runner's Avatar
As long as you are not drawing any large amperage you can use on of the 2 switched sources under the dash by the ignition switch. You can look at the pics of my alarm install which also have wire colors and supply so you know what to look for.
If you are going to draw some amps I suggest you set up your own source by using a relay to switch it on when the car is on.
Old 10-03-2004 | 06:59 AM
Beach-Rat's Avatar
Thanks.. Had hoped not to have to drop the dash shirts..
Picture of a real Painless.. the switched 12v only runs the relay..
http://www.offroaders.com/jeepfan/pwcb.htm
Old 10-03-2004 | 08:02 AM
Sorry, I meant to say to use the relay and then "trip" the relay with the switched 12V under the dash.
sanctfy
All Other Toyota Swaps
09-15-2015 03:52 PM
Mrhoadley
08-04-2015 07:08 PM
JAMGarcia
7
08-01-2015 12:46 AM
Johntom240
7
07-13-2015 01:18 AM
razorman8669
07-12-2015 01:13 PM
