Gears?
Gears?
OK, I don't have alot of time to search (although i have tried both online and on here, possibly lacking the skills?) I am getting ready to buy 33" and want to re-gear. I think 4.88 will do from what i have gathered so far. Were do i get these "gears" you speak of? Also looking at having someone that is knowledgeable install them. What am i looking at in labor cost? Just a ballpark figure. Thanks
go to 4wheelparts.com...they seem to be pretty cheap..called genuine gear..and another brand..(dont know the name)...im sure others will chime in with places that are better and/or cheaper...good luck!
Stay the hell away from Genuine Gear....
I usually recommend Precision Gear brand and find a knowledgeable person to set them up. The set up is as important (if not more) than the gear make
Check this thread I started for some info:
https://www.yotatech.com/forums/f2/r...hoenix-138384/
ZUK @ http://www.gearinstalls.com/ did a stellar job and knows his stuff. I would stick with 4:56s if your going to run 33s.
Second that--i am running 35's & 4.88's and the motor spins pretty fast on the highways--33's and 4.88's--you better like driving slow.
You can also buy your gears/thirds pre set-up from marlin crawler, inchworm gear..etc.
4.88's and 33's with an automatic is fine. Your overdrive is much higher than 5 speed trucks and your rpm won't be that high. .70:1 vs. .83:1
I have 4.56's in my 5spd 4runner. Rpm is similar to an auto with 5.29's in overdrive.
And don't get genuine gear. Almost anything else is better.
Shaun Crystal Gomban
07-30-2015 11:13 PM
justdifferentials
Just Differentials
07-22-2015 09:26 PM
