Gear Ratios?
Gear Ratios?
Does anyone know a good company to get gears from? I need 3.73's in my tacoma. The stock gears are 3.15's. This is on the 5-lug 2wd, and going from 26 to 31 makes my 4th gear almost useless. When I hit a flat part of the highway, it can hold steady in fourth, around 70 m.p.h., at like 1600 r.p.m. If anyone knows anything about gears for this, or possible a full third-member, please let me know.
R&P
I just regeared from 3.73 to 4.10. precision didn't have my ratio. I bought Yukon R&P from Randy's Ring & Pinion. www.ringpinion.com
I got no complaints.
I am going to check with Randy's Ring and Pinion tomorrow. Thanks for the info! Sounds like I might be able to pick up a posi or locker through them too.
anyone know the type of rear-end in tacomas?
I found a few different styles of rear-ends for Toyota: 7.5", 8", L/C, t-100, and V6. Anyone know for sure what type would be used here. I don't know if the "V6" is for the 3.0's or 3.4's or both. If anyone has any knowledge of this, please let me know.
Re: anyone know the type of rear-end in tacomas?
I have all the dimensions I need to find out what type of rear-end is in this. I have to go to the shop were I got the third member pulled out in the first place to get them, but they had them on hand to check around for me. I am going to check Randy's R and P, but I might be interested in those 3.73's. Keep those around, they might just be useful. I wouldn't mind the 4.10's for power, but that might kill my gas mileage. I will get back to you as soon as possible. Thanks.
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
