gear jumps into neutrel
Old 07-22-2003 | 10:36 PM
Question gear jumps into neutrel
my 92 4runner jumps out of gear in 1st why......
it happens when there is stress like going up hill is this bad or do all 5 speed 4wds do it and can it be fixed.
jamie
Old 07-22-2003 | 11:43 PM
StoryR's Avatar
My 1st Gen does it ALL THE TIME! I just hold it in first when this happens...sometimes the gears grind :cry: :cry:
But what I noticed helps is holding the clutch ALL THE WAY TO THE FLOOR for a few seconds before I put it in 1st!
Old 07-22-2003 | 11:56 PM
but is this normal,its a pain when ur climbing a hill and it pops out can it be fixed
Old 07-23-2003 | 08:12 AM
Reldnew's Avatar
Man!, when I was test driving runners (2nd gen sticks, obviously) a few years ago, many of them did this! A few private owners even admitted to this during a test drive. One guy said it had been doing it for 70,000 of it's 150,000 miles. He said he just developed the habit of hold the lever firmly in gear when accelerating in first. The tranny was smooth and quiet and never did it to me in my 30 min. test drive. My GUESS is weak motor/tranny/rear control arm bushings allowing drivetrain enough flex to knock the shifter out of gear. Oh yeah-if it is grinding alot you may have bigger issues.
Old 07-23-2003 | 08:19 AM
Sac State's Avatar
Check the throw out bearing in the clutch assembly. An old vehicle of mine had this problem and it ended up being a bad bearing.
Old 07-23-2003 | 08:32 AM
rimpainter.com's Avatar
I agree with both Reldnew and Sac State. This usually happens as clutch parts/linkage begins to wear.
Happened to us in our 92 Maxima with 178K miles.
Old 07-23-2003 | 09:04 AM
Waterboy's Avatar
I had the same problem with my '92 Toy. It turns out that it is a very common problem with these trucks. Mine would pop out of first and third at the first sign of torque. It is an incredibly easy fix. The parts cost less then $20 and it take about an hour to do. Check out this link for all the directions and part names. http://www.off-road.com/toyota/tech/shifter/index.html The directions look like they are for your truck exactly. Good luck.
Old 07-23-2003 | 09:19 AM
Hermes's Avatar
maherj is spot on with his diagnosis. I had the exact same problem with my old '92 and this did the trick.
Old 07-23-2003 | 06:30 PM
Yota Runner's Avatar
I dont know if this helps any but I had an 86 toy pu and it was coming out of gear too. I work at a toyota dealership and had one of the techs look at it and there is a little rubber ring under the stick boots that gets worn out some times. the part was like 1 dollar or so and after he put it in it shifted great.
Old 07-23-2003 | 08:46 PM
thats great maherj im going to attack it this weekend.
thanks heaps
jamie
Old 07-23-2003 | 09:48 PM
Plays_with_Toys's Avatar
Yota runner, that's the write up from the link. Strange, I have never had it come out of gear under strain, it did once on flat surface, but i don't think I had put it in all the way. Never had a problem in 4WD either.
Old 07-23-2003 | 11:32 PM
Duffdog's Avatar
that rubber thing is called the "shift shaft seat" and is the cause of falling out of gear. available at your local toyota dealer...
Blamalam
03-12-2022 08:34 AM
HollieJayyy
08-09-2015 08:59 AM
Sidherish
08-02-2015 02:42 PM
91yotapup
07-27-2015 08:19 AM
Poncho0206
07-10-2015 07:21 PM
