gas octane
gas octane
Anyone find that switching from 87 octane to a higher octane gives them higher gas milelage. Right now I get 18 mph out of a 2.7 3rz-fe. I heard going to 89 octane or 93 might give me a couple more miles per gallon. Any insight?
thanks
thanks
It's hard to say, but nothing wrong with a few tanks to see. I would suspect the mpg would do down a little bit because the specific energy content of higher octane gas is lower than lower octane gas (wierd, huh). Then again, depending on the engine, it's possible some engines (especially ones designed to run on higher octane gas, such as forced induction or high-compression) will tend to run a little more efficiently with higher octane gas, yielding a higher MPG rating.
...the second part, not so much. An engine will not run leaner/richer based on a specific octane gas. That's what an oxygen sensor is for.
I found this to be true. My truck also runs better with the higher octane. It's kind of a trade-off... our gas prices are extremely high here. I try to throw the good stuff in alternating every few tanks.
I get 23 mpg using 89octane where I used to get 19 with 87 octane. I actually got 370 miles on my last tank of gas. ALSO I noticed that my valves dont ping whenever I use 89 octane, which was the real reason I went up to 89.
Bruce
Bruce
Low backpressure can cause a loss of low-end torque, which might in turn cause you to use the accelerator more to get up to speed and use more gas in the process.
