Gas gauge won't work on 99 4Runner
My gas gauge either reads full or empty, nothing in between. Is there any way to test the sending unit without dropping the tank.
very popular topic. search.
https://www.yotatech.com/forums/f2/how-access-fuel-sending-unit-99-a-65310/
I had a problem with our gauge not reading below 1/4 tank. After dropping the tank and examining everything, I found out that our sending unit had a bad ground. You can check this without dropping the tank, Simply remove the access cover under the rear seat and attach an external ground to one of the sending unit attachment screws. See if this helps.
zd92655
03-06-2022 12:58 PM
Cesarl74
04-23-2016 06:07 PM
