Gas gauge how do I fix? 96 runner
Ok I did a search and you guys seem to already know about this but I didn't see what the fix is besides take it too the dealer. Well my 96 is way out of warrenty. So What is it that is broke?
Mine likes to read full tank all the time, it works every so often but is getting worse.
I know just reset the trip but I like when things work right
Is it a sending unit?
mine does the same thing, sorta. it wont go past 3/4 of a tank, and then it works properly past that, so its like a 1/4 tank off all the time. i dont know what to do, ive tried manually moving it up there after i filled up, but it just falls back down. good luck, i hope u find a fix
-Casey
-Casey
Re: Gas gauge how do I fix? 96 runner
This would require replacement of that part as well to fix.
You can check the signal from the sending unit and that will tell you if it is the guage or the sending unit.
So if the signal is ok from the sender, then guage is defective.
Any good manual will give you the value to test for.
I havn't done too much to it yet.
I have done some clean up and what not I think I peeled off 10lbs of grease and sludge off the underside I think it's some kinda winter coating for back east?
I also pulled all the seats and carpet out to run all the exposed wires thru plastic tubing. Moved some of that stuff around.
I put some square sliders on it and a front skid plate I also made this bumper. I'll try to attach a picture but I don't know if it will work.
at.asp?webtag=TacomaWBLandCO&guid=6E729FCE-E8A4-4E1D-B913-E258BFB46A30&frames=no
[QUOTE]Originally posted by JDeMello
[B]I havn't done too much to it yet.
http://at.asp?webtag=TacomaWBLandCO&...6A30&frames=no
the 1st one worked, and wow! What a difference just a new front bumper, a new set of skids, and some sliders can make!!
Where exactly in SoCal are you located? Because I'll be in Hunnington Beach from the 19th-2nd and would like to stop by your shop if possible.
Jason
Shop is in santa ana 2002 d s grand come on by. I won't have the runner today but I will have my truck.
Jason
Jason
Or is that it???
Ok I don't know where that is. you think you could just give me ur address and I could mapquest it?
Or is that it???
Or is that it???
2002 d s grand santa ana ca 92705
take the 405 s to the 55north exit dyer make a left under the freeway then a right on grand go down a couple lights too st gertrude make a left on st gertrude then right into the first drive way down at the end is where I'm at. I came home early today tho I'm sick!
That was the address sorry here it is a little clearer.
Eagle564
06-23-2015 11:29 PM
