FZJ80 springs on 4runner
Old 01-15-2006 | 01:09 PM
  #341
Albuquerque Jim's Avatar
Originally Posted by CCCRunner
I have a 96' w/ Taco TRD coils on Bilstien HD's and 1.25 spacers netting 22.75" fender-to-hub on 265 BGF's in the front.
My problem is the rear is about .75-1.0" lower than the front even with 1.5" spacers. This used to not be a problem with my cross-linked air shocks w/ no spacers but since switching to Billies hauling stuff just sucks.
I don't know if those FZJ80 coils would be too much, as I am trying to avoid spacers in the rear.
After installing front setup mentioned above, I kept the rear air shocks for a while and the truck sat level with a slight rake at 90 psi in the shocks. That was ideal as I like to often haul things. They rode like crap, though(hence the swap to Billies).
Any help or comments would be much appreciated.
Your Taco would require a major conversion to run coils in the rear. Buy a new set of leafs and forget about it.
Old 01-15-2006 | 01:15 PM
  #342
garrett1478's Avatar
i think he means he has a 96 4Runner with TRD Taco coils + spacers for front lift.
Old 01-15-2006 | 09:08 PM
  #343
CCCRunner's Avatar
Yes, I have a 96' 4Runner. Sorry about the confusion. My question is about the FZJ80 coils and if they are a feasable option for me, pretty much.
Old 01-15-2006 | 09:10 PM
  #344
well the LC coils are going to lift about 3-3.5" in the rear, so it depends on how much lift you have in the front. i dont know how much lift a taco coil + 1.25 is.
Old 01-15-2006 | 09:18 PM
  #345
Ahhh, I see now. My bad, I thought you were describing a Tacoma. :pat:
Old 01-18-2006 | 12:15 PM
  #346
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I was wondering if anyone had tried to use the stock Land cruiser shocks with this setup on a 4 runner? I'm looking into getting this setup and they are a lot cheaper at 30$ a piece than the OME N86's
Found the answer myself, maybe doin a little bit too luch reading...starting to miss things
Old 01-20-2006 | 12:12 PM
  #347
4RUNN!N's Avatar
Thats what I'll be running in the rear, the 97 FJ80 Front Coils and the Stock FJ80 Rear shocks, cost a total of $122. I'll let you know how it feels, now I need to get the front lift.
Old 06-16-2006 | 01:35 PM
  #348
emptypockets's Avatar
I need everyone's opinion on the LC coils. I've got dibs on a set from a '95. They're 19" long and 9 wraps. How much is this going to lift the rear. I've currently got stock springs with 2-1/2 Daystar spacers. I need another 1-1.5 inches to level things out. Are these springs gonna be too much?
Old 06-17-2006 | 08:07 AM
  #349
Bump for new info. The guy I'm buying them from said not to look at the number of wraps, but at the spring length instead????? I know much of this thread deals with the number of wraps, but I'm interested in knowing the spring length too. Thanks!
Old 06-17-2006 | 08:22 AM
  #350
nc994run's Avatar
easiest way is to just look at color codes...here's what you're looking for:
Toyota FZJ-80 Land Cruiser Coil: Right Side - Double Purple + Gray + White goes on the passenger side
Toyota FZJ-80 Land Cruiser Coil: Left Side - Green + Orange + White goes on driver side
Old 06-21-2006 | 02:30 PM
  #351
So finally, I got off my duff and ordered the LC springs from toyotapartssales.com I can't wait to see how they look and how much better the vehicle performs! Thanks for all the advice!
Old 06-27-2006 | 12:35 PM
  #352
TX-BLKRUNNER's Avatar
so can you use these coils in conjunction with 3" coil spacers? i know a pan hard mod would be required, would the track arm bars need to be lengthend? thanks
Old 06-27-2006 | 04:31 PM
  #353
dragr1's Avatar
Are you looking for 6.5" of rear lift?
Old 06-27-2006 | 05:20 PM
  #354
yeah that would be awsome! i wonder if the tundra coils in the front would work to help match up the height of the rear. it would not have to be very functional, mainly for looks, since my runner is 2wd, i would love to run 315's
Old 06-27-2006 | 06:19 PM
  #355
dragr1's Avatar
The only way to get that much lift in the front is to run a drop bracket lift like Trailmaster or such. You don't need 6" to run 315's on a 4wd, but I'm not up on the 2wd lifts-maybe someone else will chime in.
Old 07-24-2006 | 12:51 PM
  #356
hlpressley's Avatar
Just thought I would revive an old thread since I just ordered a set of LC coils today. I will try to get them on ASAP. I hope it doesn't give me too much lift with the Revtek spacers up front.
Old 07-25-2006 | 07:45 AM
  #357
I replied to your pm, and will post a current pic later today! Hit me up if you need more info!
Old 07-25-2006 | 07:54 AM
  #358
hlpressley's Avatar
Thanks bud. I appreciate the help!
Old 07-25-2006 | 12:02 PM
  #359
Here's my '02 SR5 with LC coils in the rear. BTW, it's got a Daystar 2.5" spacer lift up front. The LC coils gave me about 4" of lift when I started, but have since settled about .5" or so. The coils were new.
The rake is acceptable to me and I've had many comments on how great it looks now.
Old 07-25-2006 | 12:13 PM
  #360
hlpressley's Avatar
Looks great man. I hope mine works out that well. I am now searching for shocks and a panhard drop bar.
Quick Reply: FZJ80 springs on 4runner
