FZJ80 springs on 4runner
Old 01-12-2006 | 06:28 PM
  #321
dragr1's Avatar
Originally Posted by ROOFGOOF
Hey Dragn1, How about some pics of your rig ! I want to see the look of the 891's with the spacer . ThanX
Send me your e-mail and maybe I can get some pics this weekend.
Old 01-12-2006 | 06:49 PM
  #322
ROOFGOOF's Avatar
check PM... thanks
Old 01-12-2006 | 07:01 PM
  #323
ravencr's Avatar
Originally Posted by FilthyRich
I know it will cost $$$$. I would probably go with LC coils and airbags if I didn't have OMEs.
I don't run LC coils and airbags. I'm running LC coils with Monroe Air Shocks. It's as simple as replacing your current shocks with the air shocks of the similar length, and you'll have the best of both worlds then.
Chris
Old 01-12-2006 | 07:04 PM
  #324
FilthyRich's Avatar
Chris
Gotcha
Old 01-12-2006 | 07:32 PM
  #325
garrett1478's Avatar
just curious here, but could someone make a list of rough prices for a rear leaf conversion? i'm just wondering what all the $1000 in parts covers...
Old 01-12-2006 | 07:46 PM
  #326
964runner's Avatar
just a quick update, I have LC rear with n86 and a SAW front, plus a 2inch body lift. All the lift was easy to put in and it cleared 305/70/16. PM me and i'll email pics.
Old 01-12-2006 | 08:12 PM
  #327
Albuquerque Jim's Avatar
Originally Posted by dragr1
Chris knows what he is talking about though-he probably has the flexiest IFS third gen on the board.
Really?
Old 01-12-2006 | 08:14 PM
  #328
I am sure Schaefer has this on his site.
Old 01-12-2006 | 08:18 PM
  #329
dragr1's Avatar
Originally Posted by Albuquerque Jim
Really?
Notice it does say IFS third gen, hum open mouth and insert foot b/c I forgot the long travel guys!
How about flexiest stock a-arm IFS third gen?
BTW, how are the LC shocks working out?
Old 01-12-2006 | 08:21 PM
  #330
Originally Posted by Sonoran Steel
3.5" Lift Spring Under FJ-62 rear leaf springs, Alcan Spring 1-888-321-0870
ARB/Old Man Emu Greaseable Pins: OMEGP1
ARB/Old Man Emu Anti-Inversion Rear Shackles: OMEGS1
Currie Enterprises Spring Perches, 3.25" x 2.25" Pair: CE-7000B
Daystar FJ spring bushings, black, poly: KT02006BK
Daystar CJ-7 bump stops, black, poly: KU09036BK (Mount on top of Man-A-Fre U-Bolt Flip Kit Pads)
Man-A-Fre U-Bolt Flip Kit, FJ-60 Rear: UBFLIPKIT-60R
Toyota Part, Left Main Eye: 48415-60042
Toyota Part, Right Main Eye: 48414-60042
Toyota Part, Rear Hanger (X2): 48416-60030
Toyota Part, Bolt w/washer (X2): 90119-08686
Bilstein 5150 Series Shocks 10" Travel. Part Number: F4-BF5-A196-H1
Custom made upper shock hoop.
20" Toyota male/Toyota female rear brake line, Bonaco Inc. 909-985-3429
this is what he has for his rear setup (minus the Poly axles)
i dont know much about leaf springs...how much is this stuff?
Old 01-12-2006 | 08:23 PM
  #331
dragr1's Avatar
Robbed from Steve's site:
Rear Axle/ Leaf Spring Suspension:
Poly Performance Toyota Rear Axles: Tacoma
-CNC machined from high quality 4340 material
-Tapered design allows maximum strength
-ROLLED SPLINES
-Polished finish ensures TOTAL elimination of all possible stress risers
Eye to Eye: 46"
Front eye to axle: 22", rear eye to axle 24".
Old 01-12-2006 | 08:26 PM
  #332
ok, the ubolt flip kit is 150, the toyota OEM parts are around 200...
plus 2 leaf packs and 2 shocks and the daystar stuff...
that stuff adds up quick.
Old 01-13-2006 | 02:02 AM
  #333
RTdawgs's Avatar
Something to consider: I am only running 265/75s, which are much skinnier than 285s, which could be the culprit of more body roll than the folks with 285s. Until I get wider tires, the swaybar stays on for me.
Old 01-13-2006 | 07:51 AM
  #334
FilthyRich's Avatar
here is my rig
Before 1.25 tons of gravel:
after 1.25 tons of gravel:
About 2500# and I have some sag. Not a to, but the springs are not overly compressed nor are they the same without any load.
Old 01-13-2006 | 08:14 AM
  #335
Really? There is only so much flex possible in the front. I have low profile bump stops and I can stuff it until they hit. I also have extended length shocks and 1" top spacers so it droops until the ball joints hit the springs. There is no way to get any more flex without going to long travel.
In the rear I have the LC springs and OME's (currently) so that would be the same as well.
I really only responded above to mess with Banjo, it's been a while since I've rattled his chain.
I haven't installed them yet. I am waiting on a set of custom lower links. I know they are almost 2" longer than the OME's so that means I will have even more gas tank trouble.
I am talking to a guy here about customizing my gas tank...I'll let you all know what I find out.
Old 01-13-2006 | 08:34 AM
  #336
dragr1's Avatar
He does need his chain rattled from time to time!
Yeah, keep me posted on the LC shocks-that should be interesting. I assume pics will be posted?
By custom lower links-are you getting custom lower control arms?
Old 01-13-2006 | 11:19 AM
  #337
ravencr's Avatar
You're exactly right! Yours probably even has more compression than mine up front, because I only have the stock bumpstops. So you're the real winner, Jim!
And, in the rear I'd say the onyl difference we have is that I have a JJ joint on the driver's side of my panhard bar, but since the shocks are the same length, so we're the same the rear.
So, overall, you're the winner, Jim!
Chris
Old 01-13-2006 | 11:20 AM
  #338
ravencr's Avatar
The bag's out now, Jim!
Chris
Old 01-13-2006 | 11:59 AM
  #339
dragr1's Avatar
Chris
Schaeffer had custom rear lower control arms at one time. I could sure use some, as mine are bent pretty bad.
Old 01-15-2006 | 10:55 AM
  #340
CCCRunner's Avatar
I have a 96' w/ Taco TRD coils on Bilstien HD's and 1.25 spacers netting 22.75" fender-to-hub on 265 BGF's in the front.
My problem is the rear is about .75-1.0" lower than the front even with 1.5" spacers. This used to not be a problem with my cross-linked air shocks w/ no spacers but since switching to Billies hauling stuff just sucks.
I don't know if those FZJ80 coils would be too much, as I am trying to avoid spacers in the rear.
After installing front setup mentioned above, I kept the rear air shocks for a while and the truck sat level with a slight rake at 90 psi in the shocks. That was ideal as I like to often haul things. They rode like crap, though(hence the swap to Billies).
Any help or comments would be much appreciated.
Quick Reply: FZJ80 springs on 4runner
