Fuse box relay
Fuse box relay
Hello, New here, I did search and found the reason my dash lights stayed on after i shut it down was the integrated relay. My fuse box and integrated relay was full of dead ants.
Can someone tell me what this relay on the back of the fuse box is. It is getting enough voltage bleeding through to keep it energized to cause my problems. I can tap the relay and it will release.
Next will I have problems unplugging this small plug on the integrated relay. I have tried every thing possible and the only thing that don't work are the door locks. Thanks for any input.
I would be helpful . 1998 4runner Limited . These pics are not mine but are the same parts, just pulled off the web. It was late when i was trying to fix the problem.
rushw
07-18-2015 02:46 PM
