Fuel Injector Maintenance
What (if any) is your fuel injector maintenance protocol?
How many miles/years do you have on your fuel injectors?
In those miles/years, how often (if ever) have you had them professionally cleaned? Replaced?
Do you use fuel injection cleaner? What kind? How often?
well, the strongest injector cleaner and your best bang-for-the-buck is redline si-1 injector cleaner. it has the highest concentration of polyetheramine (PEA) and it's what i recommend. use it every 10k miles and you should be OK.
I'll have to try this next for preventative maintenance I have been running the Lucas with some decent but unverified results. Still working on the Lucas gallon so it will be a while still.
I use Luca's by the gallon. Good stuff. I did a tear down on a 5.7l SBC and it was very clean below the injectors. That however did not save it from a stuck exhaust valve.
1998 SR5 4x4 3.4L 172K
I had my injectors serviced at 160k trying to get rid of a miss at idle that wasn't throwing a missfire code. Here's a link to the company. http://www.rceng.com/Fuel-Injector-Cleaning-P43C0.aspx
There was an improvement after cleaning. But the true cause was the coil packs.
I'm currently running a can of Seafoam through the tank and some through the crankcase which has worked well for me in the past but I had no specific complains from my injectors – just doing some spring cleaning. I'm looking into and will probably try out Royal Purple's cleaner:
I am very impressed with RP's products and the reviews are outstanding for that specific product.
Amazon.com: Royal Purple 11722 Max-Clean Fuel System Cleaner and Stabilizer - 20 oz. Bottle: Automotive
Blamalam
03-12-2022 08:34 AM
Tacoma1313
08-17-2015 06:44 PM
pyramid
07-30-2015 11:05 AM
HookahRoo
07-20-2015 08:06 PM
