front suspension spacers
does anyone know if there are any 1/2 inch spacers for a 3rd gen 4runner out there I'm getting the sonoran steel 1.2 lift and I wanted to jack the front up 1/2 an inch to level my rig out.
I know i dont need them i just don't really like to look of the rear being taller than the front so i wanted to put a 1/2 spacer in the front to level it out, which would also give me a little more tire clearence.
1 Post
ToyTec sells one that is 1/4" that yields ~1/2" and some that yields ~3/4" . *** WARNING, all top spacers will allow the wheels to droop further than stock. This extra droop could over extend the CVs beyond their limits which could cause breakage*** I have the shorter ones, I wheel it hard and have had wheels full droop and hanging in the air, with no problems so far.
I've got a 10mm poly OME spacer up top of my springs sitting directly on the top of the coil and the alum toytec 1/2" top spacer above the plate. I also have a alum (I think its alum...) 5mm spacer on the shock body below the coil seat, but its specifically designed for the OME shock body so it does not work on the bilstien, though like was mentioned, you can adjust the lower coil seat on the bilsteins anyway. Adding either the toytec or OME poly spacer up top will get you another ~1/2".
The OME top spacer was from another OME kit that Kurt @ CruiserOutfitters.com just happened to have in stock and it fits absolutely perfectly on both the TRD tundra coil and the OME 880/881/882 as Kurt is running the same spacer on top of his 882s in the front of his Tacoma.
I know it sounds kinda cobbled together, but the ride is absolutely amazing on either of our rigs and mine sits about 1/2" or so taller than his in the front.
I wish I could just get the height I want out of something else, but I went a slight bit taller than what everybody else is doing. I believe I'm about 1/2 taller than SS front kit. But I need to get some fender-to-centerofhub numbers for mine and compare to SS numbers.
Anyway, I don't know any of the part numbers off-hand, but feel free to give Kurt @ CruiserOutfitters.com a call and I'm sure he'll hook ya up with the info.
-Ferg-
-Ferg-
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
