Front and rear diff. same oil?
Old 04-27-2008 | 08:11 AM
Deceptiwave's Avatar
I am changing out my front and rear differential fluids as well as the transfer case.
My brother in law has 10 quarts of new Mobil 1 synthetic 75-90 oil he said I can have, but I see that the manual calls for 80-90 in the rear diff.
Is there and danger in using the 75-90 for everything?
Thanks
Old 04-27-2008 | 09:34 AM
Taro's Avatar
No. As long as it meets the GL5 spec, it will be fine. Should say so on the bottle.
Old 04-27-2008 | 10:20 AM
crolison's Avatar
its all the same. I am using 75-90 in my f/r diffs, tranny and tcase.
Old 04-27-2008 | 11:05 AM
Awesome thanks for the help .
Old 04-27-2008 | 01:21 PM
Justinvd's Avatar
Dont you need to add friction modifyer if its l/s?
Old 04-28-2008 | 04:53 AM
mkgarrison5's Avatar
no you dont.. if you wheel a lot or pull anything a lot you should bump that up to 75w110 or 75w140. much better protection. the newer 90wts are thinner than previous mixes for some reason. even amsoil tells you to bump up in weight
Old 04-28-2008 | 09:08 AM
No I dont wheel alot. My wife drives this 90% of the time on the streets.
I do take it up on the mountain roads/puddles every now and then just to get dirty and shoot guns at stumps.
bigjstang
08-25-2021 01:41 AM
06-01-2021 02:51 PM
lledwod
08-30-2016 02:03 PM
toyoda8488
07-05-2015 11:18 PM
Vargntucson
07-04-2015 01:15 PM
