front end aligning plate?
Does anybody know wher I can get the plate that the alignment adjusting bolt goes?It is in the bottom right of the picture.Mine was pounded on by the previous owner and now that is the only part of the front end that can't be aligned.I have to cut the old one off and weld the new one in place.the left edge is flat instead of having that lip for the bolt to stop on.
Well I tried the dealer and they want a wopping $500.00 for it,and then take to a shop that can do frame work to weld it on.I thought about a wrecking yard but they would have to cut the other one off,wouldn't that warp it or could I use a die grinder?.I would rather get it cheaper then at the dealer.Any idea what that piece is called?
So are you talking about that lip that holds the adjustment cam in place? If so I would just weld a new lip on there. Or are you talking about the adjustment cam, (the off centered washer that the bolt goes through)?
Originally Posted by JEDI87
Just the lip.The cam won't adjust to where they need it.The lip on the left side is bent out.
Well guys,I just talked to the body shop and they are going to fix it for 100-150 bucks.They are going to bend the lip back and put an extra weld on it.Thank you for saving me $$$.I love being able to come to this site for help and back up.
Don't know exactly how he's going to do it,and that is worse case.It beats paying 500 for the plate and then having to have it welded.
Flying91
45
04-11-2024 05:39 PM
jasonty
41
12-23-2018 02:00 PM
09-04-2015 10:27 AM
