front diff drain plug / complete fluid change
Old 07-16-2006 | 03:53 PM
spaugh's Avatar
What size allen/hex type wrench do I need for the front differential drain plug? I already have the right one for the fill hole, but the drain plug requires a larger one.
I just finished replacing the brake fluid, rear diff fluid, oil change, went to mt-90 on my transmission, fuel filter, coolant and am left with the front diff and some grease. did I miss anything for my 140K used 4runner I recently purchased?
Old 07-16-2006 | 04:20 PM
jct61765's Avatar
http://www.4runners.org/articles/difftsf/
Old 07-16-2006 | 04:25 PM
spaugh's Avatar
I used regular oil 75w90 in the rear diff, and am going to use 80w90 in the front diff. I am not sure what to use for the transfer case? Any suggestions? I still have 1.5 quarts of redline MT-90, can I use this for the transfer case?
Old 07-16-2006 | 04:32 PM
khaug's Avatar
Be sure to grease the Zerk fittings for the u-joints and slip yokes. There should be one for each u-joint and one for each slip yoke, six in all. The slip yokes can take several pumps each. The u-joints should get one pump or a partial pump until old grease begins to squeeze out past the seals. The service manual recommends you grease these at each oil change
Toyota recommends NGLI-2 grease with moly disulfide for the slip yokes and plain NGLI-2 for the u-joints. Valvoline makes a synthetic NGLI-2 grease with moly disulfide that's easy to find. I've used it for all Zerks for years with no problems.
Sorry, can't help with the size of the wrench for the drain plug.
Old 07-16-2006 | 04:33 PM
MTL_4runner's Avatar
Originally Posted by jct61765
Ditto, it's all in there regarding diff fluid changes.
Old 07-16-2006 | 04:36 PM
spaugh's Avatar
Yep, nice site thanks! The local auto shop told me 75w90 for the rear and 80w90 for the front which is opposite of what this site says??
Old 07-16-2006 | 05:10 PM
Firefightertaco's Avatar
Should be a 10mm or a 12mm depending on your set up, some trucks have different sizes.
Old 07-16-2006 | 05:19 PM
Unfortunately, they are mistaken, the site is correct.
Old 07-16-2006 | 06:02 PM
gregbreakseverything's Avatar
This is the best writeup ever. Thanks to this, I am 100% synthetic, and it took no time at all.
Old 07-16-2006 | 06:14 PM
photoleif's Avatar
for anyone doing a 1995 4wd sr5v6 3vze pickup, all of the plugs use the same 24mm socket, which makes it really easy to find them and know you're opening the right things.
Old 07-16-2006 | 06:54 PM
Tanto's Avatar
Awesome. Just what I was looking for!
Jamie you stud! I saw the honorable mention at the bottom.
Old 07-16-2006 | 08:01 PM
spaugh's Avatar
yep, 24mm socket for everything but the front diff. The front diff has 10mm fill and 12mm drain plugs. I put the mt90 in my tranmission and transfer case. I will throw some 75w90 in the front diff next weekend when I get myself a 12mm hex tool.
So should am I ok with the 75w90 thats already in the rear diff, does it really matter here in san diego? The weather is always hot.
Old 07-17-2006 | 05:51 AM
Thanks, but I'd say Bob was the real stud for doing the writeup.
Old 07-18-2006 | 11:26 AM
jct61765's Avatar
Bob_98SR5 did a great writeup on this. Everything is there if you just look.
Old 07-23-2012 | 10:04 PM
djdarb's Avatar
Toyota Differentials
Front 1.5qts. & Rear 3.2qts.
90 or 80w90 Hypoid GL5
Transfer Case 1.5qts.
75w90 Hypoid GL5
As per all data
Old 03-07-2013 | 03:00 AM
reaj's Avatar
Link doesn't work help!
Old 03-08-2013 | 09:37 AM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
4runners.org
JF9243176
10-08-2017 05:21 AM
Valvoman
06-28-2015 03:45 PM
JF9243176
06-24-2015 05:53 AM
Hbum
07-16-2002 03:32 PM
