front brakes
Old 03-17-2013 | 09:57 AM
carly777's Avatar
front brakes
when i press on the brakes while driving the front end shakes and steering wheel also, i put new pads on put did not turn rotors, are you suppose too, if the rotor is warped do i need new one or will turning them correct it, the old pads were cracked and 1/2 left on them, wondered what made them crack 97 4rnr 4x
Old 03-17-2013 | 11:22 AM
brianh699's Avatar
Warped rotors must be replaced turning them won't be possible. Were your old pads oe? See alot of cheap pads crack under high heat and stress. Tires could also cause the symptoms you described, warped rotors usually cause a pulsating pedal.
Old 03-17-2013 | 04:53 PM
crazypaint's Avatar
Try loosening the lug nuts then tourqe them with a tourqe wrench sometimes after they been heated up many times from using the brakes it will go away
Flying91
45
04-11-2024 05:39 PM
06-01-2021 02:51 PM
jasonty
41
12-23-2018 02:00 PM
09-04-2015 10:27 AM
terminator
07-27-2015 08:13 PM
