Front Brake Conversion
How bout it guys
I have been seeing and reading about guys putting Tundra front brakes on their 3rd gen 4runners. My front brakes are crap right now and I am going in for new tires in the morning. Are the Tundra rotors & calipers etc. simply interchangeable?
Thank you in advance!
TC
TC
I did the conversion on my 98 here is the write-up and I believe I did updates on them, including replacing both rotors and pads with those hybrid pads. I used the 199mm as mine came off a 2001 Tundra, but which ever way you go it will make a serious difference and you will be glad you did. If you note in my write-up the only modification I had to do was to the dust shields and that was only filing away a very small amount, 10 minutes per wheel max. Give a look/read
https://www.yotatech.com/forums/f2/0...runner-146160/
Suggestion for a 92? I know I've got to do the rear drum conversion at some point but will the Tundra front brake parts work on a 92? Running 2016 17" rims and tires so I'll have room.
I am still waiting to see some real numbers !!!
If I am really bored one day I will sit down and crunch the numbers.
Sure WOW it makes a big difference well replacing worn out brakes with new brake parts will make a difference.
Two owners later it gets real interesting when the brake parts you ordered by the year and model don`t fit
I find my truck stops just fine with well maintained brakes .
I like my Drum brakes just fine.
Snowking
01-29-2016 03:03 PM
