Friend Needs Help
Friend Needs Help
Heya all, this is a question for any of you who know your vibrations...
friend of mine has a 93 jeep ZJ (grand cherokee), recently 6 inch lifted with 33s, has a vibration from 25 to 45, and is afraid to take it over 45.... says it starts as a side to side, then uncontrollable vibration, it did this before and after the lift... with 3 different sets of wheels and tires, and everything suspension is new from the pitman down... i say do motor mounts... he has already done
ball joints and hubs/wheel bearings... any input?
drive shaft and U joints
my CJ-5 had that problem till I shrank the tires from 35's to 32's, I also went from 7" of lift, 4" suspention ,3" body to 3" which helped with everything from rock crowling to freeway speeds. I am now running a 2" suspention and 1" body. the drive shaft angles are back to the good range and most if not all of my vibration from my earlier stupidity is gone.
Changing the angle of the spring seats(welding). add some wedges, have a custom CV made or go back to a size that will complement your buddies ride chareristics( boy do I suck at spelling). Is 6" going to help him do anything but roll over at moab. most hard core cats are putting 6" in their rock only rigs and have 15+" of travel on each axel. these dudes also run 35's for going over large holes, cracks and the big stairs. check your angles and go have some fun...
LittleUgly
15
01-02-2020 01:30 PM
zytra
01-24-2019 03:16 PM
hiluxinargentina
09-30-2015 11:12 PM
charlie_fong
09-27-2015 10:06 PM
Toys4parts
09-26-2015 01:56 PM
