Fluid comming from front shock.
The other day, a buddy of mine and i were looking at my 4runner, Its a '95 4runner auto sr5. I look under trhe front of my truck and there is some kind of fluid covering the bottom half of my front right shock. I put my finger on it and it looks kinda like oil. I know it isn't comming from the engine because its only on the bottom half of the shock. I have no idea what this is, anyone have an idea on what it is? thanks
John
John
Yeah... I kinda figured but I was trying to be optomistic, can anyone point me in the right direction on where to get a good set? I only do mild offroading. thanks for the quick replies, john
Yeah I just did a search and found some people are running billsteins and like them, I think I am going to go with them. Now, how lond would I be able to drive on this shock, I gotta have some time to get some money together...
you will want to get them changed out sooner than later, having said that, take your time going places, dont race around corners etc. if you have to baby them for a while until you get the cash for new ones they should be ok for a while. youll know, the car will get bouncier!
lee
lee
Optomistic? Oil leaking from the shock is the absolute best scenario for you. If it was coming from your engine, transmission, differential, or anywhere else really, you would be in for a much more expensive or laborous fix. You can pop the shock off and put in a new one yourself if you have the most basic set of tools. You could probably even do it with the wheel still on the vehicle in the driveway.
Well I actually do have a leak in the engine, and also, can you jst unscrew the shock and put the other one on? that easy? Would I have to jack it up or anything? I was afriad if i did that the damn thing was gonna fall to the ground or something. I just didnt want to be screwed.
All the same you'll probably want to search and find a write-up or something. That way there will be no confusion when you're sitting in your driveway with your truck jacked up and something doesn't look right.
T-Dude helped me out when I switched to Bilsteins, the front takes awhile and is a pain (but then again I am not very mechanically inclined). Look for writeup you can find torque-specs on JArunners page. Bils can be had from 169 for all 4, http://www.cabeperformance.com/detai...mance%20shocks. The do the ride a little stiffer, but are much better offroad than stock IMO. Read some of the threads before you buy.
sorry can't say for sure since you have a 2nd gen. The website used to have it listed for several different 4runner generations. I would give them a call or check bilsteins website.
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
YotaGreenhorn
06-27-2015 07:00 AM
dirtrider0129
10
06-24-2015 12:24 PM
