Firing order on a 3.4, Help
Hey to all, got the new wires and I think I crossed the wirs. Heck there's only three, but somehow th truck doesn't seem to be running smooth when I started so before I start changing the wires around, Anybody got the firing order, which wires go to which coil pack? 1-3-5 to ........, thanks, EDH
According to my Chilton's manual, for the 5VZ-FE (97 to 2000), the firing order is 1-2-3-4-5-6, believe it or not. Standing in front of the vehicle, looking towards the back, the left bank of cylinders are numbered 1,3 and 5, and the right bank of cylinders are numbers 2,,4 and 6(front to back). Make sure everything else is reconnected, are the boot wires on tight? Maybe a bad plug as well. Good luck!
EDIT: nevermind, I found a place:
http://www.delmarlearning.com/browse...=AU&cat2ID=CHM
firing order
Originally Posted by bbagwell
I believe they no longer make Chilton manuals you can only get Hayes.
and also here along with the Haynes:
http://www.amazon.com/exec/obidos/tg...glance&s=books
Firing order 3.4
Hope you get it figured out!
Spend the $$ to buy actual Toyota OEM wires. You will eventually...
The Napa wires I had for a short time made me lose gas mileage, power, and caused lots of interference on the radio. She ran noticeably better with Toyota parts.
YMMV
YMMV
I realize this post is old but my problem is new and similar to h7009’s. I
replaced the wires + plugs on my ’96 T100 3.4L yesterday(NKG dual electrode
plugs, Bosch wires). When I fired it up it sputtered & shuttered, miss-fired, but
would idle. I swapped the wires on cyls 1 & 3 thinking I mixed them up.
Same thing.Then I then discovered I left he coil disconnected on cyl. 5,
so I reconnected it. Still same thing. I re-swapped wires on 1 & 3 so now I
have wires as such:
1 - 2
3 - 4
5 - 6
The motor will not even start now. On the Haynes diagram in this thread,
does the little box to the left of the cylinder diag. show which cylinders the
wires are supposed to be connected to?
1 - 4
3 - 6
2 - 5 ???
Thanks.
8lugger
have wires as such:
1 - 2
3 - 4
5 - 6
1 - 4
3 - 6
2 - 5 ???
Thanks.
8lugger
I think I found my answer on the thread below. I'll know for sure
when I get home an hour or so to try it.
https://www.yotatech.com/forums/f2/h...k-plugs-40801/
foampile
12-18-2022 02:29 PM
TJWilly
07-31-2015 03:05 PM
mengquis
07-13-2015 11:39 AM
