Factory Locker??
Old 04-07-2003, 06:13 PM
Shane's Avatar
I think it was on the PBB where someone was estimating 30% stronger than stock birfs.
Old 04-08-2003, 07:02 AM
tomus1000's Avatar
Originally posted by Eighty7ToyTruck
maybe ill run 33s, either way, i wont decide that until i have rebuilt and built up the motor and added more boost....
How are you adding more boost to an '87 Runner? How is it getting any boost at all? Is it a turbo?
Old 04-08-2003, 07:46 AM
44Runner's Avatar
One would assume he has a 22R-TE as that would be a stock option in 87...
Then again there are plenty of other ways to go for forced induction...
Old 04-08-2003, 08:15 AM
jx94148's Avatar
FYI I currently have 4.30s and 32" tires. Its WAY too tall for any decent crawling. The speedometer seems to be right on the money though. I see dual cases in my distant future. I'd have to sell my motorcycle to do that now though. That's not going to happen.
Old 04-08-2003, 08:25 AM
  #25
44Runner's Avatar
Keep in mind that no matter what gears you have in your axles, you will never be able to crawl without some other major form of reduction like a second t-case or lower t-case gears. axle gears are just for the road. if i was building a trail only rig i would just keep 4.10s. They are stronger and you already have them. even 5.71s (bad idea in any rig) don't make a rig crawl worth a darn.
Old 04-08-2003, 12:42 PM
  #26
Eighty7ToyTruck's Avatar
yes, its an 87 sr5 turbo model, and by adding more boost, i will have a boost controller, upgraded wastegate and a blow off valve, 4.88s should be plenty for the 35s or 36s with a 4.1 tcase setup....
Old 04-08-2003, 08:08 PM
  #27
44Runner's Avatar
I would still do 5.29s for 35s, but it is up to you. do you have a 5 spd?
Old 04-09-2003, 05:19 PM
  #28
5.29s are too low for me... especially if i go with the transfercase kit, and no, its an auto...
1uzRunner
63
11-10-2018 03:58 PM
justdifferentials
14
06-11-2017 08:36 PM
LotOMiles
09-14-2015 11:45 PM
zz_denis
09-06-2015 03:43 PM
Badfish740
09-04-2015 04:21 AM
Quick Reply: Factory Locker??
